Engine Oil temp sensor
Old Mar 4, 2009 | 10:46 PM
pete15's Avatar
I resently had my check engine light go on, so i took it to the dealer to have them scan it. They told me the eot sensor went bad. So i bought the sensor and i plan to put it in tomorrow. What i don't understand is that i checked my oil recently and noticed it was really low and i just changed it 1000 miles ago. Basicly what i am asking is my oil being so low so fast have anything to do with that sensor? I don't think i am burning oil. I have the 5.4 Thanks
Old Mar 4, 2009 | 10:50 PM
bigbronc's Avatar
This might be a dumb question, but do you realize that this engine takes 7 quarts of oil on an oil change?
Old Mar 4, 2009 | 11:13 PM
pete15's Avatar
yea and i always check it when im done and here and there. After the oil change it was right below the max on the dip stick, now its a little below the halfway point. which means it went down about 1/2 quart in 1000 miles
Old Mar 4, 2009 | 11:33 PM
bigbronc's Avatar
As per Ford recommendations. Do not fill it to the max. Inside the hashmarks is fine. Overfilling these mod motors will lead to troubles, vibrations, etc.
Old Mar 5, 2009 | 12:47 AM
jerzpilot's Avatar
did you check under the engine, oil plug and oil filter for leaks while the engine was running after the the oil change?
Old Mar 5, 2009 | 03:10 AM
Fifty150's Avatar
You're either burning or leaking oil. Both of which is suppose to be normal if you're only losing 1/2 quart over 1,000 miles. None of that makes any sense. To me, it is simply not normal to burn or leak oil.
Old Mar 5, 2009 | 08:23 PM
pete15's Avatar
Just to state i dont think its because of the oil change i did, i work at lube stop, so i do it often. And i looked all over the engine for leaks i even put it up on my lift.
