raditor fluid leak
Old Feb 27, 2009 | 05:30 PM
jeffscc's Avatar
Unhappy raditor fluid leak
i have a 1992 ford f150- 5.0l engine. i have a small leak on the back of engine where the transmission and engine meet. what do i do? it is a very small leak but i am worried about it please help if any one has any ideas.
Old Feb 27, 2009 | 06:27 PM
bigbronc's Avatar
WTF is leaking, and where from? Leaks usually show up underneath where they start.
Old Feb 27, 2009 | 06:53 PM
roushstage2's Avatar
Rear main seal?
Old Feb 27, 2009 | 08:50 PM
Matts ford's Avatar
guys the title says "Radiator fluid leak"
i'm gonna take a guess and say an externally leaking head gasket/cracked head.
whats the mileage? has the coolant ever been serviced? has it overheated?
Old Feb 28, 2009 | 07:34 AM
jeffscc's Avatar
the mileage is 167,000 and yes the coolant has been serviced
Old Feb 28, 2009 | 08:13 AM
jbrew's Avatar
Do you know where it's coming from? Heater core lines maybe? I can't see it from here
Old Feb 28, 2009 | 11:16 AM
tjk_in_cny's Avatar
you got new smiley's to play with
Old Feb 28, 2009 | 11:52 AM
jethat's Avatar
If it not coming from the heater core its a freeze plug. Transmission removale would be required to fix that and its not a leak that should be ignored. Had a freeze plug fail on a POS Dodge I had and it caused an engine melt down. I would think it the Heater/hose/core leaking because I've never heard of the freeze plugs developing leaks in a newer ford. Guess it could be a headgasket to.
Old Feb 28, 2009 | 01:26 PM
jeffscc's Avatar
how hard is it to change the head gaskets
Old Feb 28, 2009 | 01:30 PM
Matts ford's Avatar
its not bad on a 5.0. you gotta pull the upper and lower intak,e and valve covers, and exhaust manifolds, the a/c compressor, the air tube that runs from pass side head to the driver side head, etc. and have the heads checked. its a pretty self explanatory job on these engines. your better off getting a chiltons or haynes repair manual for it though. it goes through it step by step.
but first find out what the problem is.
