Damage to piston
Old Feb 11, 2009 | 08:55 AM
Maxon4x4's Avatar
Damage to piston
I recently had to pull my heads and on one of the piston heads there is some damage there is two indentations (gashes) about a 16th deep from a helicoil that fell inside of the motor and the motor was turned over while it was in there.
My question is how thick are the piston heads and should I replace it or will it be ok,
Old Feb 11, 2009 | 08:00 PM
CRASH594's Avatar
The bigger question is was it enough to bend a rod. If not and depending on how picky you are you could blend it smooth and let it ride. If you leave it as is the sharp edges could cause a hot spot. This will couse detonation (bad). Need to check the head and valve seats also.
Old Feb 11, 2009 | 08:28 PM
Faster150's Avatar
helicoil ftl
