It is going to happen
Old Feb 23, 2009 | 10:06 AM
cadman's Avatar
Thumbs up It is going to happen
Well I have started on my 1997 F150 to 2005 V10 conversion. I will try and keep track of what has to be done. I do have a link to pictures and will have them posted as we make progress. I am also going to replace my cab mounts and add a body lift. Wish me luck
I will have plenty of beers when done. or maybe during.
http://www.flickr.com/photos/1010765...7614226262649/
Bryan
Old Feb 23, 2009 | 10:13 AM
Veteran: Army
good luck, if you read camdenlakes <-? install thread his notes may help you out
what ECM and trans are you going to be using?
Old Feb 23, 2009 | 11:13 AM
tjk_in_cny's Avatar
Bryan
Awesome job with the photo gallery. I learned alot just by viewing your pic's.
Hopefully you can upload some video when it's all done. Good luck with the project.
TJK
Old Feb 23, 2009 | 11:36 AM
minimonster17's Avatar
what transmission will you be using? if you are going to swap to the E4OD/4R100, you will need the longer 7700 series torsion bars for the torsion bar crossmember to clear the transfer case, if this is a 4WD truck.
Old Feb 23, 2009 | 12:14 PM
Blown F-150's Avatar
Looks like a great project.
Let us know what issues you run into along the way. I saw the dent in the roof from the cab removal, too bad. I hope you go with some heavier torsion bars for the added weight in the front.
Old Feb 23, 2009 | 12:58 PM
cadman's Avatar
I am using the 05 ECM, the original trans, we will see how it holds up.
I am planning on getting the heavier Torsions, I have the code 6 in 1997, What was used on the F250LD 7700# What code???
The dent was trying it with a single chain hoist. We had to regroup.
It has a Superlift kit in it now.
I am 46 and wont do alot of REAL crazy things, will tow some 4wheelers in an enclosed trailer, some hunting and a little mudding.
Old Feb 23, 2009 | 01:00 PM
Veteran: Army
is teh V-10 ecm compatable with your original trans??? if not you may need a trans or a manual valve body and tell the ecm you've got a manual
Old Feb 23, 2009 | 01:47 PM
Gotts2BMe's Avatar
no but I do think that they still used the 4r100 in 2005.
Old Feb 26, 2009 | 12:20 PM
Veteran: Army
if it's a 2 valve then yeah it should have the 4r100 behind it
Old Feb 26, 2009 | 12:26 PM
Camarothatcould's Avatar
SWEET!
Can anybody guess what this EXACT motor was in before???
Old Feb 26, 2009 | 12:27 PM
Gotts2BMe's Avatar
even the 3vs had the 4r100 till 2006 I believe then they updated to a newer one, 5 speed auto maybe, but thats when they updated it in the diesels anyway.
Old Feb 26, 2009 | 12:49 PM
blackedoutV6's Avatar
definately subscribing
Old Feb 26, 2009 | 03:26 PM
cadman's Avatar
The motor is setting in now. I hope to start the wiring this weekend. Here is a pic of the ECM that I drew up in Solidworks, I will post the pinouts and what plug is for what when I get it figured out. I haven't had a chance to get the diagrams or pinouts yet.
https://www.f150online.com/forums/me...4-v10-ecm.html
Old Feb 26, 2009 | 03:38 PM
RayD's Avatar
The Super Dutys got 3v gas engines and the 5R110 at the same time so the 05 would have had a torqueshift unless it was a manual trans truck. Diesel SDs had the torqueshift in 03.
I'll be interested to see how this swap works. Keep the updates coming!
Old Feb 26, 2009 | 04:17 PM
cadman's Avatar
It was an automatic truck, but when I run the computer thru the interchange it comes up that the 5.4 and 6.8 use this computer. Didn't the 5.4 use a 4r75 then?
