Anyone know anthing about underdrive pulleys?
Old Feb 19, 2009 | 09:19 AM
brianricks2007's Avatar
I'm looking to put a set of underdrive pulleys on my 1999 F-150 4.6
anyone with any kind of info would be greatly appreciated... what do i need, how to install, performance difference, ANY help with this is appreciated...
Old Feb 19, 2009 | 04:49 PM
Veteran: Army
what rib belt do you have???
I ran MAC's for a while and they were great
Old Feb 19, 2009 | 05:07 PM
tlt008's Avatar
I had a set of March undersrives on my 00 Mustang GT w/ 4.6l. Can't say whether they did anything or not because of the fact that I did a few other things at virtually the same time. A buddy of mine who is a mechanic at the Ford dealership did say that the dealership had voided warranties before because of the pullies.
Old Feb 20, 2009 | 03:33 AM
i've got an 8-rib belt... and are the pulleys for a mustang the same? or do i need totally different ones?
Old Feb 20, 2009 | 03:35 AM
Veteran: Army
MAC and ASP seem to keep people happy
Old Feb 20, 2009 | 05:47 AM
lew52's Avatar
Im not sure but i think the mustangs are 6 ribs.... The underdrive pullyes are a good mod... You may need a air impact gun to get the alt pulley off...
Old Feb 20, 2009 | 11:40 AM
Fifty150's Avatar
I think that w/ a '99, his warranty is over.
INSTRUCTIONS FOR 97-02 4.6/5.4 FORD TRUCK PART # asp528774 / PART # asp527374
97-01 4.6/5.4 FORD TRUCK
Auto Specialties recommends that these pulleys be installed by a qualified mechanic.
1. Loosen water pump bolts.
2. Remove belt. Tensioner is accessible from under truck. CAUTION: Insure truck is properly secured on jack stands before accessing underside of truck.
3. With transmission in first gear and emergency brake applied, remove harmonic balancer bolt. An impact wrench will be required with automatic transmission. Remove harmonic balancer using a 3 prong balancer remover. Remove water pump pulley.
4. Apply high temperature silicone sealer to underdrive harmonic balancer keyway. Install harmonic balancer onto shaft. Use 12mm x 60mm bolt to engage harmonic balancer on shaft only far enough to engage factory bolt then remove. CAUTION: Do not tighten 12mm x 60mm bolt as damage to threads may occur. Torque factory bolt as follows: 1.) Torque to 75 lb/ft. 2.) Back out 1 turn 3.) Torque to45 lb/ft and then tighten an additional 1/4 turn.
5. Install new water pump pulley and factory belt. Insure belt is seated properly in all pulleys. Tighten water pump bolts. (NOTE: on the 1999 -03 5.4 trucks, there is an aluminum nipple sticking out from block. It is located at the bottom right hand corner near waterpump. You have to grind this off in order to get the water pump pulley to fit.)
6. Start engine. Inspect all pulleys to insure no wobble and that belt is properly installed.
Copyright ©2003 Auto Specialties Plus Inc. All rights reserved. Any unauthorized duplication of any portion of this site strictly prohibited
Old Feb 20, 2009 | 11:44 AM
Fifty150's Avatar
