Replacing stock plug wires.
Hey guys, what brand would you recommend getting to replace the stock plug wires?
My truck has 125K+ and im still running stock, and the idle is a bit rough, plus the start up it getting kind crummy after sitting for a few hours. I replaced the sparks last spring, but the wires looked ok, so I left them.
Any suggestions?
Any suggestions?
You could try an aftermarket wire, but i would stick with motorcraft wires. Mine did that exact same thing after replacing the plugs. So i did the wire 4 weeks later, it runs great now.
Wires are only good for 130k miles or so.
the modular engines dont like aftermarket wires.
Yea, wires will fix your troubles. Go with Motorcraft wires. I made the mistake of going with the duralast wires and there was always one that would not stay on the plug. VERY annoying! I buy OEM now.
I change my plugs every 60k miles, and, even if the wires look good, they get replaced. I never just replace plugs only.
