MAF swap question
MAF swap question
I have a 03 Screw 5.4 and i wanted to get a bigger maf. Can i use a 90mm maf from a Lightning? It will bolt up to my Outlaw air intake. But what about the Maf sensor can i use mine from the stock maf? Would my stock one (maf sensor) be calibrated for my injectors?
Thanks for the help.
Tony
Tony
I have a 03 Screw 5.4 and i wanted to get a bigger maf. Can i use a 90mm maf from a Lightning?[/QOUTE]
Yes it will fit but the L 90mm is calibrated for 42# injectors.So you would need a tune.
Without a blower you would be wasting time and money and would end up with no power gain.
[QOUTE=Tinner105;3592221] But what about the Maf sensor can i use mine from the stock maf? Would my stock one (maf sensor) be calibrated for my injectors?
Tony
Tony
if you put you stock meter in a bigger housing, you would be getting a bad reading from it du to the greater volume of air.So you would need a tune for it.And again,,,you would see no power gain from it. So it's not worth doing!
Phil
Im putting a 75mm tb on the truck/and porting out the plenum is the reason i wanted to up the maf. With the new style injectors and the fresh tune and TB more air than needed is better than less than needed. And i have it Hyperteched as well.
I just didn't know how the airflow was sampled.
On our SuperCoupes we use the C&L mafs and they have different sampling tubes to takecare of the air sampling.
thanks
tony
thanks
tony
hey tinner I'm a fellow supercouper as well I have 4 of them.
anyway, I was searching google and found this thread, I swapped a 351w and 5spd in my 92 along with a t4m0 ecu. I just got a MAF code and was searching housing swaps. Stupid maf was out of range and causing my car to die intermetently out of no where.
kaboom, bye bye motor on a canned tune. As stated above the stock MAF is fine for what you are doing (I ran mine even with 24# injectors)
since your porting your TB Elbow and running a larger TB look into selling the hypertech and getting a custom tune(s) done, it'll be worth it
