View Full Version : Engine
  1. idle issue?
  2. I6 300 1990 Fuel Injected Intake Manifold??
  3. Can't find OBDII port
  4. 2003 Expd what does this hose connect to?
  5. No Power Steering
  6. Good deal on NPI HEADS
  7. 2004 engine programmed?
  8. Fuel Injector Cleaner
  9. 2007 ranger power?
  10. Engine oil level
  11. torque question
  12. 87 F150 I need help
  13. 5.4L problems
  14. 4.6L gutless
  15. Ranger 2.3l 4 Cylinder oil gage droped engine died
  16. Whats an average price for Timing Chain replacement
  17. Check engine light
  18. white smoke
  19. 4.2 mods
  20. ebay cop's/plugs
  21. superchip
  22. 5.4 liter power?
  23. 1992 with crazy coolant issues
  24. 4.6 power question
  25. P0402. Help!
  26. '00 5.4 expi has bad hesitation
  27. engine oil pressure
  28. lash adjusters... hard time here.
  29. How long can you drive with no OIL PRESSURE?
  30. 113K spark plug photos
  31. Pros/Cons of UD Pullies?
  32. 2000 ford explorer code reading
  33. Engine Woes
  34. Update on my performance
  35. Make me go faster!!
  36. Sudden Acceleration 4.6L V-8
  37. Is my thermostat sticking?
  38. Rough Idle
  39. Multiple spark plug launches.
  40. Spark plug question
  41. 4.6 misfire on #6
  42. PO401 code
  43. Iron Vs. Aluminum Heads
  44. compression ratios
  45. Troyer Fan Electrical Meltdown...2nd in Three Months
  46. supercharging an f150 4x4
  47. Canada/5.4 cam phasers/warranty?
  48. Serpentine belt removal
  49. engine oil
  50. Time cert plug hole repair kit F/S
  51. How do you read the VIN ?
  52. Did Time-sert spark plug repair, now truck is missing badly
  53. Anyone Tried these COP's???
  54. Posting an attachment
  55. 4.6 HP question
  56. help w/ gas mileage
  57. Nos
  58. Egr P0401/p0402
  59. Battery light keeps coming on
  60. Loosing Acceleration
  61. Broken Spark Plug
  62. Patman03sprcrw Towing help/recomendations
  63. 90 f150
  64. Truck Champ
  65. Long Tube Headers
  66. p1406
  67. sparkplug blowout
  68. 2006 4.6 header question
  69. How to reset the PCM
  70. Strange smell
  71. Sluggish, hesitation during heavy accel.
  72. Overheated :(
  73. Bad shimmy, ECU possibly?
  74. Screech before it shifts.
  75. having engine issues
  76. More Power?
  77. 1996 F150 I6 Not running like it used to..
  78. Overheating???
  79. Rapid increase in oil consumption?
  80. Spark Plugs
  81. Spark Plug number 8
  82. OMG oil filter is TIGHT
  83. Autolite XP
  84. First Oil Change
  85. Need help desperately
  86. stupid 4.6 f150/mustang question
  87. Last Manifold Bolt - Ideas?
  88. new coils
  89. O2 Senser Code
  90. 01 4.6 valve lash adjustment
  91. What is redline on a 2007 5.4?
  92. rough idle after head replacement
  93. Factoy spark plugs?
  94. mustang intake manifold
  95. Vacuum Lines
  96. So how do you know if the plug is seated enough?
  97. Strange sound
  98. Intake Manifold/Head Question
  99. 4.6 V8 Spark Plug Blowout
  100. EGR code
  101. wont idle down while coming to stop
  102. Help Please!!!
  103. P1401
  104. oxygen sensor
  105. 99' fuel pump relay fuse
  106. 98 F150 Fuel/Ignition issue.
  107. Battery Light?
  108. Trans Mount - They still manufacture these?
  109. 4.6 supercharger kits? 2006
  110. 2002 5.4L which heads
  111. heater core replacing....help!
  112. Light Duty Diesel News
  113. When should I change the air filter??
  114. Why are MotorCraft Air Filters So Expensive?
  115. Sluggish '98 SuperCab w/ 4.6 & 5sp manual
  116. Cleaning super chip
  117. plug wires and coils
  118. #4 Misfiring
  119. engine swapping
  120. how to port and polishing the throttle body
  121. Another remote oil filter question
  122. intake manifold
  123. 04 5.4l constant knock
  124. Anything to watch out for when buying?
  125. Mixing fuel system cleaners
  126. fuel filter replacement 2003 f-150
  127. need direction 4.2 overheat
  128. Engine Bogging
  129. guides and tensioners????
  130. Timesert Spark Plug Tool for Rent
  131. navigator missfire
  132. Will a 2 row radiator fit my truck?
  133. its not idleing steady
  134. Service engine light
  135. Running rough 1.5 - 2k rpm's
  136. Spark Plugs???
  137. 2006 5.4 How much oil?
  138. EGR Insufficient Flow fix
  139. Rear Cats. Drill out or remove?
  140. pulling front axles out
  141. Starter Stays Engaged Too Long
  142. converting a 01 f150 to a lightning
  143. What is your gas mileage average?
  144. whitch should i get
  145. Yahoo! 17 mpg!
  146. Lightning cams
  147. Launched plug?
  148. Lifter noises
  149. Lucas Oil in my 2006 Ford F-150 KR
  150. 5.0 swap from '95 to a '92
  151. Problem starting engine, doesn't turn !!!
  152. 5.4l Dohc
  153. Pulley Comparison
  154. 1999 5.4L rough running
  155. stutter and a light???
  156. over heating while towing
  157. 5.4 Timing Question
  158. Crown Vic engine in an F150?
  159. Stage 2 Questions 4.6 (JMC help)
  160. Tensioner pulley
  161. 1999 F150 Problems....
  162. Need help with code
  163. 2002 F150 Spits, Sputters and Chugs, whole truck shakes at startup
  164. Bogging / Hesitation please help!!!!
  165. programing???
  166. easy power?
  167. heads, cams, and intake manifold off mustang
  168. Where do I go for the info?
  169. Project In The Works
  170. Pull-Off!!!
  171. 5.4L will not start
  172. 06' 4.6 forced induction?
  173. 1st post...new to the F150...looking for info
  174. Specific motor break in question
  175. #2 Cyl. Misfiring
  176. Please help
  177. 03 5.4 80,000 Change coolant?
  178. Looking for help from
  179. P01401, Please Help
  180. Juddering when reaching motorway speeds
  181. '86 5.0 supercharger?
  182. no throttle response 05 SCAB 5.4
  183. synthetic oil at 90,000 ?
  184. About to do the New COPs.
  185. Knocking
  186. synthetic oil and filter??????
  187. Coil Problems
  188. Turbo vs. super?
  189. Please Help Need Info Now!!!
  190. 2003 Expedition 5.4 ?
  191. Loud Knocking From Throttle Body Area??? Anybody???
  192. Hesitation on 06 Screw 5.4
  193. 00 4.6 oil everywhere
  194. 98 f-150 wont idle
  195. Clunk and Humming noise.
  196. 5w 20
  197. Oil pump question
  198. fuel superheater
  199. Knocking
  200. need a response ASAP, cylinder position
  201. 5.4L reliability question
  202. Rough, noisy idle at startup
  203. efan turn on temp?
  204. What does a bad torque converter sound like.
  205. Water pump failure
  206. Any Thoughts
  207. 4.6L Stroker Kit???
  208. Wrong Area BUT......
  209. engine swap????
  210. plug wires popping off
  211. cleaned the throtle body today :help:
  212. Check engine soon light on
  213. maintenance before vacation?
  214. Dyno Services ?
  215. Not Sure Where To Put This
  216. New Truck
  217. Oil Type Change
  218. What brand for the front 02 sensors?
  219. horrible gas mileage
  220. 10-30w oil
  221. 5.4 in a Regular Cab 4x4?
  222. Fuel mileage on '04-'07 4x4 Supercrew w/ 5.4L?
  223. New f150
  224. Remote oil filter kit, different oil filter question.
  225. Engine randomly shuts off
  226. Where are the Spark Plugs
  227. 98 Silverado
  228. Spark Plugs
  229. PCM pinouts....
  230. p0191
  231. 2001 4.6L Fuel pressure regulator hookup ?
  232. Gotta LUV the V-10
  233. Tick noise
  234. Not sure
  235. 2004 Shakes while Towing
  236. small rattle or knock
  237. So Watcha Got?
  238. Egr
  239. starter problem
  240. 2001 F150 7700 5.4l
  241. reving on its own
  242. Strange 1989 F-150 Problem
  243. posi trac
  244. Vibration at idle
  245. what sensors work when the engine is cold
  246. Found my miss!
  247. anyone have factory pcv part number for '02 4.6?
  248. iat reference voltage not 5V
  249. buzzing from ecm after truck is turned off
  250. rough idle
