a/c clutch change
Old Jan 23, 2011 | 12:45 PM
Zippy321's Avatar
a/c clutch change
Any help would be great! The a/c clutch froze up on my 1998 4x4. Do I need to remove compressor from truck? Also how do you get what looks like a clip out of front of pulley?
Old Jan 23, 2011 | 01:07 PM
projectSHO89's Avatar
The clutch hub and pulley can be replaced without removing he compressor from the vehicle.
Use a large 90 degree snap-ring pliers to remove the ring.
Old Jan 23, 2011 | 01:20 PM
Zippy321's Avatar
Thanks will give it a shot.
Old Jan 23, 2011 | 02:25 PM
Steve83's Avatar
If the hoses are long enough, and there's clearance between the engine & wheelwell, it might be easier to do with the compressor detached from its bracket, but don't open the refrigerant system.
Old Jan 23, 2011 | 02:29 PM
61 falcon's Avatar
it can be done with the compressor in place. you could remove the fan and shroud to gain some extra room.
Old Jan 23, 2011 | 11:45 PM
jackjroadster's Avatar
hi,i own a '98 F150 4x4 4.6 V8 and my ac clutch froze up. I was wondering if I could do it myself since I've read some instructions on auto repair manual and it seems to be easy but my friend says it's a big task to repair it myself. And what I saw was a general instruction manual. is this really not a novice repair job?
Old Jan 24, 2011 | 10:43 AM
Steve83's Avatar
Can you change the belt? Do you have snap-ring pliers?
Old Jan 24, 2011 | 05:24 PM
Zippy321's Avatar
I got it apart but it came apart in pieces. Just hope I got everything off that needs to come off. Time to order the new one. Will check back in a couple days and let you know how it goes.
