Tune UP PROBLEM
Old Feb 27, 2011 | 06:14 PM
1998f150wes's Avatar
Tune UP PROBLEM
well i went to do a tune up on my f150 w/ 4.6 v8 and i started on passenger side got the first one out no problem the second one WILL NOT COME out i went to take the second one out and it justs keeps spinning. what could be my problem and how am i going to get it out yes im talking about the plugs and the 2nd plug will not come out of the head itll just keep turning
Old Feb 27, 2011 | 06:41 PM
jbrew's Avatar
Originally Posted by 1998f150wes
well i went to do a tune up on my f150 w/ 4.6 v8 and i started on passenger side got the first one out no problem the second one WILL NOT COME out i went to take the second one out and it justs keeps spinning and the last person to work on it was lonestar Ford in Houston about 75,000 miles ago and i know the person who worked on it too so guys what could be my problem and how am i going to get it out
What are you talking about , plugs? Try using a little punctuation, you know, periods, coma's, a little capitalization in the correct areas would help.
Old Feb 27, 2011 | 06:55 PM
yes the plugs the 2nd one will just keep turning and not come out
Old Feb 27, 2011 | 07:01 PM
MGDfan's Avatar
Please - allow me.
Good evening, engine Gurus. If I could petition for a miniscule portion of the Exalted Jbrew's time, it would be most appreciated!.
I endeavored to perform a tune up on my f150 w/ 4.6 v8. I began by replacing the spark plugs.
I started on the passenger side and managed to get the first one out with no problems. Yay!
The second one, however, WILL NOT COME THE F@$^%$$^&&K out! It just keeps spinning!
The last folks to work on it were employed by Lonestar Ford in Houston, about 75,000 miles ago, and I know the feller, aight?
Hence - my empassioned query, guys: WTF could be my problem, and how am I to get this spark plug out?"
My fervent hope is that the folks cognizant of the relevant specifics will offer to speculate upon the nature of my issues."
Thank-you in advance, kind sirs.
MGD
Old Feb 27, 2011 | 07:21 PM
dozerdog's Avatar
stripped threads- buy a kit to fix it or take to a garage.
Old Feb 27, 2011 | 07:27 PM
MGDfan's Avatar
If it is stripped - use this: http://time-cert.com/
If the socket is just not seating on the plug hex, it could be due to foreign matter in the plug well. Try cleaning it out .
MGD
Old Feb 27, 2011 | 07:29 PM
my parents own a shop i just like to stay as far from them as possible cause then they want me to do something for them but i already have a kit to fix it i just cant get the plug to come off
Old Feb 27, 2011 | 07:47 PM
If it's not a Timesert it won't last. That's the only insert that lasts other than the custom inserts made by blownoutsparkplug.com, which they do not sell.
Old Feb 27, 2011 | 08:02 PM
jbrew's Avatar
Originally Posted by MGDfan
Please - allow me.
MGD
Thanks, I know there's free wear out there that will do the same, - well almost. Almost as good as you did that is..
Gizmo has an online program that's pretty good I hear, for English -
http://www.techsupportalert.com/best...n-and-arts.htm
Old Mar 10, 2011 | 07:52 AM
well this has helped but how am i going to get this spark plug out ive been driving it like this for a couple weeks now (runs the same as before) i still need to get that spark plug out but how?????????
Old Mar 10, 2011 | 09:04 AM
y2kxlt's Avatar
Is there a rock or something not allowing the socket to engage the hex part of the plug?
Old Mar 10, 2011 | 02:03 PM
Toyz's Avatar
If it were just spinning like you said, and your driving it everyday.... it would have spit the plug out already. There must be debris blocking the plug socket. You need to look in there and see what is going on like mentioned before. It is not uncommon for debris to partially fill the plug well and not allow a plug socket to fit over the plug. Tricking you into thinking the plug is just spinning, when yet it is not. Confirm that first.... as like I said, if it were spinning like you think, the plug would have spit by now.
Old Mar 10, 2011 | 08:04 PM
jbrew's Avatar
Make absolutely sure the plug well is clear. Then use a plug socket with a rubber insert. This will hold the plug well enough to where you can lift the plug while loosening. That's your only chance, that little bit of lift could make the difference, IF the threads are somehow screwed up.
If that doesn't work, you'll have to remove the head.
Old Mar 10, 2011 | 08:25 PM
1997bigredf150's Avatar
I would confirm with everyone stating something being cloged in there. I had mud caked in the wholes so bad i too thought that the plug kept spinning. Took about 100psi out of a aircompressor with a good extended blower tube to clean it out.
Old Mar 10, 2011 | 09:33 PM
okay thanks guys ill try that this weekend
