1998 4.6 pinging bad.
I have a 1998 4.6 extended cab with flare side bed. The motor pings real bad. Mostly when under acceleration, any rpm over 3k and all the time when hauling a load. It has new motorcraft plugs, good wires, just cleaned the maf sensor. Installed a new pcv valve and hose and evap hose. the hoses were changed due to some previous codes that were being thrown. It looks like the ecm was changed since it has a seperate sticker on the door jamb. 8-48r f8ae-6e061-cmd is the calibration code on the door. Then truck has no mods. But i cant say if the computer has any change to the orginal programing. any input?
I don't think either can be cleaned or adjusted. Rather than go into a lot of detail, I suggest getting a Chilton manual from a parts store. (may only be able to find Haynes, they are both owned by Haynes). I don't care much for 'em, but they're about the only manuals available other than factory. The knock sensor is not an easy one to change, have to pull the intake manifold to change it, it's in the valley below the manifold. I believe the other 2 are not real bad to change. No way to test the knock sensor, only the wiring loom to it. The other 2 can be tested, but a small amount of work to replace.
