2003 engine
i took my 2003 f 150 4.6 8cyl ford truck to a mech.today all at once it started making a noise like a rod knocking no engine lights came on just all at once anyway he looked at it and said it had two noises comming from it a knock and a ticking i need a new engine it will cost 2900 plus 650 to put it in and maybe a couple of little parts . does this sound right everyone else i talk to says get a second opinion sounds to high for a rebuilt engine
Did your 'mechanic' drive the truck? If there is a sudden problem maybe the 'mechanic' is the problem. You should seek other opinions before putting a new motor in. Also did you notice a knock that was not there before? Was the truck out of your sight? You may wind up buying a new motor which is just yours cleaned. You have to watch some 'mechanics'.
