A bit of a random question.....
Old Jan 11, 2011 | 01:48 PM
Damomasts's Avatar
I have a 1998 F150 Supercrew. As far as I know she is a 4.6l. However, I recently looked under the engine and the bottom of the block is stamped 5.4L. Am I missing something here or is the bottom the same on all engines but the heads make a difference?
I am not a mechanic but would love to know what is going on.
Any help would be appreciated.
Cheers
Damo
Old Jan 11, 2011 | 02:00 PM
phil6608's Avatar
4.6 and 5.4 are two different motors! And they both have the same heads.
Did they even make a supercrew in 98?
Phil
Old Jan 11, 2011 | 02:11 PM
Justin_w32's Avatar
I thought 01 was the first year for super crew...
Old Jan 11, 2011 | 02:17 PM
Damomasts's Avatar
Sorry chaps, that should have read Supercab, not Supercrew.
What does it mean then that I read this 5.4L on the bottom of the block just below where the headers bolt on?
I had the head gasket replaced amongst other items like the radiator, wtaer pump etc... Surely these wouldn't have fit if the motor was actually 5.4?
Old Jan 11, 2011 | 04:38 PM
phil6608's Avatar
Head gaskets are the same.So is the Rad.
Probably the water pump also but I'm not certain about the water pump.
If it has 5.4 on the block,,,it must be a 5.4
Phil
Old Jan 11, 2011 | 04:58 PM
CRDick's Avatar
can you tell by the width of the valve covers like on a 454 GM????? just a thought
Old Jan 11, 2011 | 05:31 PM
Toyz's Avatar
I would also imagine if the block is stamped 5.4 then it is a 5.4L
phil6608's Avatar
No,,lol.
Same heads on both motors.
Old Jan 11, 2011 | 05:36 PM
Toyz's Avatar
Ask the dealer to run the VIN, if the engine hasnt been swapped before.
Old Jan 11, 2011 | 08:00 PM
Does it have coil packs and spark plug wires (4.6), or does it have coil on plug (5.4)? What's the 8th character in the VIN? "L", "M" or "Z" is a 5.4, "6" or "W" is a 4.6.
Old Jan 18, 2011 | 05:29 AM
Damomasts's Avatar
How do I tell the difference between coil packs and spark plug wires and coil on plugs? 8th character of VIN is 6 but haven't checked if this corresponds with the number on the engine.
If I post a photo of my engine, can someone identify if its a 4.6 or 5.4?
Cheers
Damo
Old Jan 18, 2011 | 08:16 AM
If it does or doesn't have spark plug wires, you will be able to see that easily. However, if the engine was swapped, it's possible that they kept the wires. 5.4's all had cops from the factory, 4.6's didn't switch till 2000 or so.
Old Jan 18, 2011 | 07:11 PM
munoxide's Avatar
Different intakes also, no?
