What plugs to get ?
What plugs to get ?
Been doing some reading but seems there is quite some contreversy on the different plugs available. Im coming up on a 100,000K and its time to get those old plugs out.
I was looking at the E3's but seems they are not holding up as they say.
What are the best plugs available for the 5.4L 3V ??
What are the best Cops ?
Truck is an 05 Lariat
sounds good thanks.
Are these the ones ? http://www.summitracing.com/parts/AC...gine+Type%7cV8
I saw a different part number but not sure which one is better..
QUOTE=phil6608;4510304]The stock Motorcraft COPs are the best!
Do not change them unless you have a bunch of bad ones and if you have one bad one.Just by a new Motorcraft COP from Rockauto.
Phil[/QUOTE]
Phil[/QUOTE]
on
Motorcraft SP507 or SP515 if you want the engine to run right.
Champion 7989 if you aren't totally worried about the engine running like it should, but you'll never have to worry about plugs breaking off again.
Brisk Racing if you don't mind replacing them every 30K miles or whatever it is, and you won't ever have to worry about them breaking off.
Autolite HT1 or E3s if you want to waste money.
Yea bosch plugs suck i tried them and ended up changing them out for autolites. I had the bosch plugs in for about 3,000 miles and when i took them out the center electrode was red and didnt look good. Ive had the autolite platnums in for over a year and they are great no complaints. I shouldnt say the bosch plugs suck for every vehicle.... they just do in fords. For some reason fords dont like them. I would have never put them in my truck if it wasnt for the guy at advance sayin they were good plugs, then i started reading on here about all the people that have problems with them. But the second time i changed them with the autolites i was alot faster did it in about a hour. good practice i recon. i would stick with the motorcrafts or autolites IMO.
