Engine Hesitation and Rough Idle
I have a 2001 F-150 with the 5.4L. 165k miles all original SP injectors and COP.
CEL is coming on and code typically shows 'misfire on #5'. Sometimes it shows 'too lean on bank 2'
Engine idles rough and drives with hesitation and shaking.
I was originally thinking bad COP or plug but the too lean code makes me think injector or maybe fuel filter.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
I'd go with the fuel filter too, it's probably time.
Also at 165,000 you don't have a bad plug, I'd say they were pretty good. But alas they are worn out now.
Like jbrew said check for moisture and change the plugs and filter. In fact it might be getting close to needing some regular maintainence.
