another egr question
Old Jan 17, 2011 | 02:01 PM
gray1988's Avatar
ok i have a 98 2wd 4.6
my egr was actin up, so this past weekend i took it off and cleaned it, well its still not just right. my question is if i remove it (block off plate etc) will i need to tune my computer or will it run 100% without a retune
thanks
Old Jan 17, 2011 | 04:29 PM
Cetansapa's Avatar
Did you disconnect the battery when you cleaned it?
Old Jan 17, 2011 | 04:59 PM
phil6608's Avatar
You would need to turn the EGR off in your tune. And your gas mileage will suffer!
Phil
Old Jan 17, 2011 | 05:20 PM
gray1988's Avatar
yes the battery was unhooked
Old Jan 17, 2011 | 06:32 PM
dirt bike dave's Avatar
IMO, if your EGR is bad, you should get a new one.
The EGR is an integral part of the system on modern motors. On a street motor, you are not going to gain anything by eliminating it. But if you take it out, you run the risk of overheating, among other things.
Before you block it off and drive the truck, you might want to do a little research on how the EGR actually helps your motor run cooler. Just my $0.02.
Old Jan 17, 2011 | 06:51 PM
Are you getting a CEL and codes? If so, what are the codes?
Pull the throttle body and clean it, especially the EGR ports in it.
Old Jan 17, 2011 | 07:22 PM
gray1988's Avatar
yes it read the egr code, and the TB is the only thing i havent cleaned, ran out of time monday came to fast
Old Jan 18, 2011 | 08:28 AM
WHICH EGR code, please? Exact P-number.
Old Jan 18, 2011 | 08:41 AM
Tumba's Avatar
EGR codes rarely have anything to do with the EGR itself. Most of the time it is either a blocked EGR port, and bad DPFE, or a vacuum leak.
To help you the exact codes are needed as GLC requested.
Old Jan 18, 2011 | 10:47 AM
38Chevy454's Avatar
Did you clean out the passages in the manifold elbow? You need to remove the elbow to clean it completely, it has intersecting drilled passages.
Blocking the EGR will cause you to get DPFE errors, as it measures EGR flow. So it requires modifying the computer to keep it from setting the CEL and codes.
Old Jan 18, 2011 | 01:17 PM
jbrew's Avatar
Go to Scorpio for Good Info and Diagrams. You need your DTC to trouble shoot. This site makes it easy, - it's a good one to bookmark -
http://www.fordscorpio.co.uk/egrmonitor.htm
Old Jan 18, 2011 | 07:14 PM
dbell1's Avatar
I have a 2001 4.6 and I also have delt with the EGR problem. I dont remember the exact codes but it was for the EGR and DPFE. What it boiled down to was I had to take off the throttle body and clean the port. You cannot get to the far side of the port with out removing the throttle body. A tech at ford said the 4.6lts were bad about that, especially police cars because they sit around and idle all the time.
Old Jan 19, 2011 | 07:58 PM
gray1988's Avatar
i cant remember what exact code came up ill have to go get it ran again?
