O2 sensor part number
I need to replace the passenger side upstream o2 sensor.
does anyone know the part numbers for this replacement? I found Bosch 15717 and 15718 as well as Motorcraft DY1093.
for an 02 5.4L
for an 02 5.4L
I've searched some more and can't find anything.
Look up Motorcraft number at www.forparts.com then go buy it.
i know to get bosch or motorcraft, but, of all these parts listed, which can i or cannot use?
glc has the number above.
If your Manifold and Y pipe is OEM, stick with "Exact fit". That's the easiest route. I would replace with the same, either Bosch or Motorcraft; whichever you have currently, -and replace both upstream at the same time for best results. No need to worry about Alternate, Universal, etc, -unless you have a custom set up that relocated bung locations further downstream.
Yea, - "Exact Fit" - Upstream.
thank you. i have a completely after market exhaust but the driver side o2 still fit in the new location.
reason i only asked about the passenger side is because i had longtube headers sitting around for a year or two. finally got around to installing them and turns out they didn't fit. had to get the exhaust done so i got shorty headers and everything else had been cut out or replaced already. i had already cut the sensor wires for a TEMPORARY extension installation but that stayed under there longer than i wanted.
again, thanks for the help.
