Mis-fire
Mis-fire
Well long story short my truck was jerking while it was accelerating and I thought it was my U-Joints because I couldn't hear a misfire and a CEL never came on but it wasn't my U-Joints.
You can clearly hear a misfire now (6 days later) and a CEL still hasn't come on, I just changed all my spark plugs out 15,000 miles ago, the fuel filter just a little shorter then that. Should I keep running the truck and wait for a CEL to happen?
Sounds like a bad coil(s) Took awhile for cel to come on mine also...I replaced them all...I believe these are it:http://cgi.ebay.com/ebaymotors/NEW-I...Q5fAccessories Good luck
Edit:Just checked and those coils are the right ones DG 508.
get the 10 pack, the set for the v10 then you have spares. I've been using the for a couple of year with no failures. Also might save the known good coils..
Also does anyone have a part number or something for the bolt that holds the COP down? One of them was stripped last time and we just used needle nose pliers to tighten it down. I'm trying to avoid that this time.
Would these work on my truck?...
http://cgi.ebay.com/ebaymotors/NEW-I...item19bdee83c5
Do you have the link for that?
Well I was inspecting the COPs today, took each one out, pulled the spark plugs out. One of the spark plugs had rust around the bolt part, and looked a lot more worn then the others. On that specific one the COP was hard as heck to pull out and I can not physically put it back in.... I'm gonna order a new set... but any suggestions?
Thank you...
