shorty headers
Old Jan 12, 2011 | 04:37 PM
Kr619's Avatar
shorty headers
gibson part number 3515 to be exact I tow fragrantly its a 4.6 so no one that i know makes long tube are they worth it. . . I'm considering this beacuase my engine is out and that way I dont have to pay installation cost
Old Jan 12, 2011 | 05:10 PM
rcantu's Avatar
people say it makes no difference in power. definitely is easier to work out out of the truck so if you gonna do it, may as well do it now.
be sure the gaskets are good ones so you don't have problems in the future.
Old Jan 12, 2011 | 05:15 PM
Kr619's Avatar
Well if it those not make a difference I'm sure I can find other things to do with $450
Old Jan 12, 2011 | 06:35 PM
Fordfanatic101's Avatar
I say do it I have heard shorties help with bottom end
Old Jan 12, 2011 | 06:45 PM
phil6608's Avatar
Thumbs down
Don't wast your money on them!
Gibson makes a nice header but they don't help whatsoever.
Had them on my 5.4
Phil
Old Jan 12, 2011 | 06:53 PM
tenzip's Avatar
Do you fart a lot when you tow?
Old Jan 12, 2011 | 07:12 PM
Toyz's Avatar
I've never pulled a 4.6 but imagine they are similar to the 5.4. I wouldnt be so sure theres room to install the shorties while the engine is out? Not a lot of room on the fender side firewalls when they come out or go in. I duno.
Old Jan 13, 2011 | 08:24 AM
I heard shorties actually hurt low end torque.
Old Jan 13, 2011 | 09:07 AM
phil6608's Avatar
Sure you can install them wile the motor is out, But the question is,,,,,will you be able to get the motor back in with them on it???
Phil
Old Jan 13, 2011 | 04:03 PM
JimAllen's Avatar
FWIW, I was involved in dyno testing shorties vs stock and long tubes vs shorties on a late model GM 5.3L. The shorty system picked up 8 peak hp over stock and while peak torque didn’t change, the dyno graph showed some changes in its location in the rpm range. The long tubes picked up 21 hp over stock and 13 over the shorties. Peak torque jumped 10 lbs-ft over both stock and the shorties but it was above both stock and the shorties all the way across the graph, especially at the upper end. They were able to squeeze a bit more out of the long tubes with some custom tuning.
Couldn't say for sure if the same applies to Ford modulars, but I'm not sure I would spend $450 for 8 hp.
I forgot to say that the 8hp included a cat back system.
Old Jan 14, 2011 | 03:04 AM
Kr619's Avatar
have the magnaflow full exhaust and my bad their BBk
Old Jan 14, 2011 | 08:34 AM
jbrew's Avatar
Joey (built54) did the Dyno comparisons for the 5four. From factory to shorty's, same, no change. From Shorty's to Long Tubes, - graphed a 30 hp gain with another 35 torque. That's the only Dyno I know of for the truck engine set ups.
Old Jan 16, 2011 | 11:48 PM
f150greg's Avatar
I did the pacesetter longtubes and wouldnt look back. Totally different truck. i would call it at least 20 hp on a 5.4. If you live in California ( like me) You will need to find a shady smog guy. unless you would be willing to change it back every 2 years.
Old Jan 17, 2011 | 07:52 AM
JimAllen's Avatar
Originally Posted by jbrew
Joey () did the Dyno comparisons for the 5four. From factory to shorty's, same, no change. From Shorty's to Long Tubes, - graphed a 30 hp gain with another 35 torque. That's the only Dyno I know of for the truck engine set ups.
Interesting. That follows pretty well with the GM 5.3 tests I referenced above. I think this is a case where "common knowledge" is correct. Do long tubes or save your money, I guess.
Old Jan 17, 2011 | 04:38 PM
Veteran: Army
plus the power under the curve is where it matters, not just the peak's, unless you are holding your dyno sheet whilst towing or racing
