View Full Version : V8 Engines
- performance mods? - 95 4.9 6cyl
- 90k miles ???????????????
- Seafoam users, need some help
- TPS Adjust Question
- whats going on with my truck?
- Please help...
- Cold start clatter 5.4l
- Is a 99 motor a direct swap for a 98 motor?
- Fuel Additives
- Antifreeze / water mix???
- Are the heads on the 4.6 and 5.4 the same?
- Hello!! And 5.4 L question
- Heavy Duty Radiators??
- 5.0 surges after rebuild
- Higher Idle In 4WD Low??
- Need a new starter??
- 89 F150 I-6 start/run problems
- 1997 with hesitation/miss
- Misfiring and Oxygen Sensors
- Overfilled Oil
- 99 5.4 won't crank
- exhaust leak and missing?
- Can't believe nobody knows anything about this
- Coolant Temperature Sending Unit...
- Truck dies, need help!!
- Fast idle when warm?
- Electric Fans
- normal clunking noise?
- saw a blk truck the other day with the emblems outlined in gold,who does this
- 2003 Screw gas cap light on in the dash
- engine rebuild
- battery light flickers after changing serpentine belt
- Oasis Anyone? Carfax?
- lost power
- Help, Cylinder Location
- Mustang guy got his first F150 (1992, F150, 302v8), what are some mods I can do?
- 4.6 at WOT
- Engine upgrade
- Whats in a name ?
- Engine shakes violently
- Fuel pump kicking on when motor off?
- engine swap
- '01 Explorer V-8, AWD, Advice please
- '93 F150 Cruise control not working!!
- Noise from gas tank
- blue smoke
- Step by Step on 4.6 PI Head Swap
- 5.4 V-8 rocker arms
- Oil Sending Unit
- Zex Nitrous Oxide
- Coils
- Call me a woos- SPARK PLUGS
- Water In Spark Plug Holes!!!
- milky engine oil at the filler cap
- NEED HELP (codes & problems) please
- '97 4.6 died today
- engine shuts down
- Check Engine Light - '97 4.6
- Squealing from engine bay? (in cold)
- Bypass Oil Filter
- Thermostat Question???
- F-250 with 5.4
- Look what I found when fixing "P 303"
- 1987 F150 4.9 hard startup
- How many here really use Walmart Supertech oil ?
- Maybe someone can help me?
- engine codes
- Best HP gains for the buck??!
- Anyone lost an engine because of oil?
- need help
- Plugs For Nitrous
- Question about durability
- Starter/Flywheel Noise?
- changing plugs on a 4.6
- 2004 F150 Heritage 4.6L Programer??
- P0175 Code
- Coils!!!!!!!!!
- '97 5.4 rocker arms
- Gas pedal sticks at first...
- idle problem associated with battery
- aux fan noise
- Oxygen Sensors?
- 1998 4.2 rough cold starts
- 1990 f150 engine view
- head gasket problem? HELP!
- Filling new Oil filter w/oil
- Couple more questions on P0401 (EGR)
- Biggest Gas tank to fit a Supercab Shortbed?
- 2 questions, please help
- WD-40 freezing point
- 300,000
- ok a repeat question I KNOW-what are best plugs
- 4.2, rough cold starts
- What triggers the P0171 error ?
- #3 Misfire - Will this fail smog?
- Code P401?? Check engine light on.
- Conventional vs. Synthetic Oil?
- 19 # injectors
- can't find my after cat O2 sensor E350 van
- Oil Filter Solution
- Took her to the repair shop today
- transmission fluid in gas tank
- #3 coil replacement tricks for 99 5.4
- coolant additives
- new fuel pump for rear tank 92 f150
- o2 sensor, best price?
- P1401 Code F150 2001 4.2 V6
- Cylinder head distroyed: need advice
- 3.8 SC engine swap
- Please help
- mass air conversion for 1993 bronco 5.8 e4od
- Do you need to pull the engine for a head swap?
- Getting more horsepower out of the 4.6
- Cold engine dyno numbers
- MAF size question
- Electric Fans & Snowy Weather...Part II
- Cold start humming noise until warm
- code P1451
- Yet Another Ridiculous Oil Subject Thread
- f150 Diesel?
- TPS voltage?
- P0303 #3 Spark Plug Misfire
- 2003 supercrew mini overhead console wiring
- Remanufactured break-in period...?
- 86 E150 Has Weak Injector Signil Want Run
- Oil pressure problem at during cold outdoor temps......
- Head Gasket Leak, how do I know
- 5.4 SOHC to DOHC swap
- Low oil pressure in fresh rebuild 5.4
- Oxygen Sensor
- roller motor
- Older Ford Parts
- 4.6 to a DOHC 5.4
- P0301 misfire
- Has anybody heard of.......?
- bad gas cap= bad mpg?
- High Idle
- F-150 engine accerates with clutch is depressed
- 2003 4.6L Oil leak
- 5.4 Engine Questions
- 1999 F250 vs 150 Whats the difference? HELP!
- 98 Romeo question....
- v10 engine
- 99 F150 replacing the heads
- didnt start this morning
- What radiator should I buy?
- Spits and Sputters when cold Please help!
- 1988 302 w/AOD tranny into 1981 F-100
- Timing adjuster for F150 5.4?
- What build date did they make a change on the spark plug holes
- Engine stalling
- best place to get gatorback belt?
- Water in #7 & #8 spark splug housing
- Help/Head Gasket/How to approach Ford
- Need start up info
- '02 '03 4.2's still POS's ???
- 1999 Expedition 5.4 How Much Nitrous to safely Spray?
- Oil Level at time of oil change
- Home skillet
- Ignition Timing Specs '96 5L F-150
- The 4.6 V8:what should I know?
- PI heads and increased compression ratio...
- 5.0 rebuild injector question
- injector cleaning
- How do you change PS fluid?
- running rough
- F150 5.4L engine - When for F250/F350
- Service Engine Soon light on
- mpg has dropped alot, cant figure out why
- PI Heads and Mustang intake
- 2003 Screw 5.4 clear coolant ? 6750 GVWR Pkg ?
- Is it worth it ?
- Remanufactured engine cost...?
- high idle, torque conv engage, disengage
- ps whining
- check engine light
- 97 F150=dead?
- 1 Double Plat Plug 7 Single Plat
- high revving on startup
- Rising fuel $
- How to improve 5.8L Gas milage?
- Testing oil every 1,000 miles - Results for Mobil-1 synthetic
- Big Trouble in Little V-8
- Foreign object in cylinder???
- Testing COP
- How do you....
- skipping at low rpm's
- Denso Iridium plugs on a 4.6
- swap '83 GT 5.0 into '95 F-150
- coil pack replacement
- Do all spark plugs need to be the same?
- Cutout at 100 mph - governor??
- Slight kind clunky noise in front end
- Loctite on Spark Plugs
- How to get center pin in trailer plug to be "hot" henin reverse
- Plug and Wire board preferences
- 97 4.6 pcv port
- Fuel pressure test port
- Fluctuating / Erratic Oil Pressure Gauge Fix
- OBD II scanner?
- vibration problems at stoplight in gear
- transmission
- Engine injectors
- Fuel injectors
- why do coils go out?
- 4.6L MPG and lifespan
- HP gain for adding PI heads to a 98 5.4?
- Does Mobil1 make a type S filter?
- Headers Installed
- misfire cylinder 2
- 4.6, ready to kick bucket?
- Comp Cams/ Anyone install?
- Difference in Dyno's
- Some more info
- 91 F150 cranks, won't start, EEC codes pulled
- Strange noise in Subzero temperatures??
- Chip Plug-in point on ECU
- Replaced only one spark plug
- Running Rough - Any Ideas
- engine oil cooler
- PCV Valve Replacement
- Need help/ engine miss
- 351m
- Starter frozen?
- 99 f150 starter replacement
- Replace or rebuild?
- Espar Diesel Fired Engine Coolant Heaters
- Aqua-tune
- Anybody know of a website link with photos on changing an EGR Valve?
- Leaking head?
- Stay away from Bosch plugs
- Adjusting TPS to .99
- JBA Shorty Headers Bolts
- Electric Fans and Snowy weather...
- loud knocking when cold
- *SPAM* Ebay Item
- 2003 Roush Mustang
- 5.4 The final word. Techs Please Read
- "Check Engine"?- 1998 5.4
- engine specs?
- Wattage Draw on Block Heater
- Slight Vibration at 39MPH &...
- Is 20w-50 Oil in a '98 4.6 a good idea?
- Code Scanner
- 98 F-150 4.6 Intake Info??
- oil sending unit
- Valve Cover Torque Specs?
- High Idle Speed, 1990, 5L, 40,000 Miles
- problems with new 351
