Oxygen Sensor
Old Jan 23, 2004 | 11:56 AM
Black Dawg's Avatar
Oxygen Sensor
I need to replace my O2 sensor on the right side of my 98 4.2 XLT, and Im wondering if anyone knows what tool I need to use or is there some other trick to getting them out?
Thanx,
Black Dawg
Old Jan 23, 2004 | 12:57 PM
Johngs's Avatar
You can rent/buy one from AutoZone.
Old Jan 23, 2004 | 01:26 PM
JMC's Avatar
JMC
25 Year Member
The socket size is 22mm. I use a 22mm open end wrench. If you cut the plug off a box wrench will fit over it. Penetrating oil, not WD40, will also help. When you install the new one do not forget the anti-seize.
Regards
Jean Marc Chartier
Old Jan 23, 2004 | 03:56 PM
Black Dawg's Avatar
OK its done. I just got back from the hobby shop. It was a little easier than I thought and I didnt forget the anti sieze.
THanx fellas
Black Dawg
Old Jan 24, 2004 | 12:37 PM
jvangel's Avatar
Did you go in thru the wheel area, or from underneath the truck? Did you use a socket or a wrench? Thanks I have to replace my passenger side, close to the manifold. Not alot of room up there.
Old Jan 24, 2004 | 01:14 PM
Black Dawg's Avatar
I had to do my passenger side also. Take the wheel off then remove the piece of rubber on the wheel well just over the brake assembly. I used a wrench to get the sensor off. It was pretty easy to do, just a little elbow grease getting the wrench to turn at first. Like mentioned before, dont forget the anti sieze when installing the new one. Now Im thinking about doing the other side to help my milage more. Ive put about 45 miles on my truck since I replaced it yesterday and no engine light yet so Im guessing I did it right. Good luck with yours.
Black Dawg
Old Jun 4, 2004 | 06:45 PM
Tomwin's Avatar
What is this anti-seize stuff that you put on before you install the oxygen sensor? And what exactly is it for? I have to replace the front driver side one and want to get it done right the first time.
Old Jun 4, 2004 | 07:33 PM
Black Dawg's Avatar
The Anti-Sieze will prevent the o2 sensor from getting stuck in the hole for good. Over time the o2 sensor will rust and it could rust so bad you'll never get it out again.. Anti-Sieze will prevent that from happening.
Good Luck!
Old Jun 4, 2004 | 08:18 PM
hcmq's Avatar
make sure you get high temp anti sieze or it will just boil out on the exhaust manifold. You need to also use high temp AS behind your rotors.
Old Jun 4, 2004 | 08:27 PM
max mitchell's Avatar
Here's the "serious" product line:
www.astinfo.com
