head gasket problem? HELP!
Old Jan 29, 2004 | 12:54 AM
ossy_ko's Avatar
Unhappy head gasket problem? HELP!
87 F150 straight 6
antifreeze disappearing, probably mostly out tailpipe but some boils over -- engine does not overheat
high kms, probably head gasket? big or small problem?
advice, how to-, place to find info on procedure?
thanks for any info you can offer
Old Jan 30, 2004 | 05:17 PM
Throttle's Avatar
It can become a big problem, but straight 6's are relatively easy to replace.
Have you performed a compression test or have you had the coolant tested for petroleum distillates? One or both will verify a blown head gasket.
Alldata online is a good resource as well as a Chilton's repair manual.
Alldata
Chilton's
