Timing adjuster for F150 5.4?
Old Jan 19, 2004 | 08:16 PM
lilxtra's Avatar
Have a guy who wants a timing adjuster for his '01 F-150 but I don't know who sells one.I'm told one from a mustang MIGHT work but don't want to go thru the hassle of ordering one then having to send it back.Do you guys know of one?Thanks guys,Scott
Old Jan 19, 2004 | 08:30 PM
silver bullit99's Avatar
yes BBK makes one.
Old Jan 19, 2004 | 09:29 PM
Neal's Avatar
Cool
HI!... STEEDA make's a timing adjuster for the MUSTANG 4.6. One of the FORD magazines installed one on a 5.4 that was transplanted into a MUSTANG GT. The got pretty good results with it. Don't run it in conjunction with a chip unless it's a custom tune to take the new timing into account.
Old Jan 20, 2004 | 07:19 AM
lilxtra's Avatar
Thanks guys! Did they have to make any modifications to it to make the 4.6 ones work on the 5.4?
Old Jan 20, 2004 | 11:25 AM
JMC's Avatar
JMC
25 Year Member
Here is how it works;
The crankshaft position sensor is relocated outside of the front cover using a special bracket. An adjustable trigger wheel is installed on the crankshaft. This trigger wheel has slots that allow the wheel to be rotated on its mount changing the location that sensor picks up the signal. It is an external pick up so any crap from the road can get on the sensor and trigger wheel.
IMHO If you already have a chip you are kind of wasting your money. Unless you race and require more timing at the track or are running lots of boost or nitrous and want to retard timing then you don't realy need this. A properly tuned chip/flip chip can do all of this for you without the hassle of unscrewing/readjusting the wheel every time you want to change timing.
Regards
Jean Marc Chartier
Old Jan 20, 2004 | 04:55 PM
I have one, and i have a chip, i just still have not installed it yet on my 4.6, i have the microtuner and the timing is set way low so i'm gonna crank it up with this, then when i run juice should i feel like it, i can retard my timing and be safe.
