normal clunking noise?
Hello. When driving along at 35 MPH and getting off the accelerater, is normal to hear a clunk from some part of the drive train? dealer told me that it has to do this because the yoke{?} has to have some play.I owned this truck for 4 years and I never heard this before until last week.Any suggestions would be very appreciated. Am I being to fussy?
There has been some talk on this board about this.
Some have said it is a u-joint gone bad.
Also in some cases the slip yoke at the transmission gets dirty and gets a little stuck so when you come to a stop it binds slightly then clunks to its proper position.
You could also have something going bad in the suspension like a bad shock, loose leaf spring, worn tie rod, etc.
I am sure someone else will chime in with some good ideas.
Mine makes a wierd clunk noise if I slow down from like 15 to like 5 or so to go over a speed bump and then hit the gas a little to start going...
Not sure... my truck barely runs right now though...
Let me explain what happened in one word... Nitrous...
