P1401 Code F150 2001 4.2 V6
Old Jan 26, 2004 | 02:30 PM
AHAAP's Avatar
i got a code P1401 on the tester,the service engine soon light is on,any ideas before i take to the shop? the parts computer said dealer only.truck had 86000 miles on it.any help would be appreciated/
Thanks in advance, truck is a 2001 F150 V6 4.2 2 wheel drive standard The Auto zone guy said the code was EGR circuit high output?is there a way i can fix this without going to a shop?
Old Jan 26, 2004 | 02:56 PM
AjRagno's Avatar
You have a bad DPFE sensor. It's about an $85.00 emissions part. Ford used enough of these substandard sensors that they extended the warranty on this part to 70,000 miles.
You can easily replace it yourself. It's #4 in the illustration. Check the hoses and connection first to make sure everything is connected, but odds are very high that the sensor is dead.
Old Jan 26, 2004 | 04:05 PM
AHAAP's Avatar
thank you,is it the the plastic piece that 2 hoses go into the bottom ?it isnt very big?
THanks
Old Jan 26, 2004 | 04:11 PM
AjRagno's Avatar
Yes.
Old Jan 26, 2004 | 04:18 PM
AHAAP's Avatar
wow $85.00 it doesnt look any bigger than a box of matches.it doesnt look very hard to change either.there isnt something hidden is there?lol
Old Jan 27, 2004 | 07:01 AM
AHAAP's Avatar
thank you AJRango,i got the part after work,took 5 minutes to put on,the light is off.there are 2 different types of that part,mine was the small one $68.00.the shop told me it would be $161.00 installed (riiiight)
Thanks again,AHAAP
Old Jan 27, 2004 | 12:38 PM
Throttle's Avatar
All Ford OBDII Codes
AHAAP,
Glad you got her fixed. If you ever run into another "Dealer Only" code, you can check it out on the link above.
