Wattage Draw on Block Heater
Hello folks,
Just curious if anyone knows how much power the factory block heaters pull while plugged in.
It was -7* last night and I left it plugged in all night long keeping the juices warm. It sounds like there is a pump circulating the coolant throughout the motor on my 01 f-150 Screw.
I am guessing at least 1000 watts...anyone know a tried and true number?
Thanks!
--Justin
Thanks!
--Justin
Look at the tag on the end of the cord. I't about 100 watts if that. All it is is a freeze plug heater. The hot water rises which circulates the water.
You only need an hour or two in the garage, but better to keep it plugged in if the truck is outside in the wind. It would be less than $10 a month if you had it plugged in all day for the whole month. What would that be, 25 cents a night.
Ok, I did a search, you could be right.
Plug it in
"Q. How much does it cost to use?"
"A. A major engine heater manufacturers recommend that freeze plug heaters be sized at approximately 150 watts per liter of engine size. A 2.3 liter/4cylinder engine would cost about 3.1 cents an hour to operate. A 5 liter/8 cylinder engine would cost about 6.7 cents an hour."
thedieselstop
"The only con is the cost of electricity. You are burning the equivalent of ten 100-watt light bulbs. [Some have stated they have the 1500-watt version, but I'm prety sure that those who have actually crawled under the truck and read the writting on the heater reported it was 1,000 watts.]"
Time needed to pre heat an engine block
"The car was a Ford Crown Victoria w/4.6L engine, the engine heater was an "in-line" type made by Pinedale Products of Chalk River ON. It is rated at 600 watts and circulates coolant at about 1 gal./min."
Plug it in
thedieselstop
600 Watts according to the engine block heater option for a 2003 5.4L equipped F-150. It also has a 11OV AC electric heating element.
I can tell mine is plugged in when I hear it buzzing. Also: I left it plugged in one day when the temp started near zero. When I went out to start it that evening, it was 35 degrees and the coolant temp gauge was already above the cold mark.
