View Full Version : Transmissions
- Clicking in rear-end when stopping
- What's the big deal between the two auto trannies???
- Where can I find a tranny online?
- 5sd mazda, what can I do to inprove on it?
- E4OD Shudder
- Overdrive light flashing
- Severe vibration from 30 to 40mph??? HELP
- Hard shift 2nd gear to 3rd
- Which brand of shift kit to buy for '98 4.6 ???
- Use of the overdrive switch on E4OD
- E4OD for sale
- Only 4R100 in 7700lb,5.4l Supercabs for 2001
- Has anyone had this standard tranny problem?
- Sometimes tranny shifts hard
- TRANS.OIL SHOOTS OUT FROM UNKNOW PLACE AROUND WHERE DIP STICK IS
- Banks Transcommand upgrade
- my tranny is whinning, not me
- 95 mazda POS trany
- Transmission Repaired
- B&M ShiftPlus+ Installed in '97 F-150
- 4 weeks in dealer!!!!!!
- Clutch Starter Safaty Switch
- Tranny rebuild questions?
- Cracked Flex plate
- manual trans help needed fast...
- Hey Factory_Tech - a question.....
- Delay in shifting
- are all e4od's the same?
- SOmone has gotta know this one...5 spd in a '86??
- Fluid Change
- New Tranny
- Gears
- redline vs amsoil
- Shuttering trans fix
- Transmission additives ????
- I'm Bummed -- Anyone Know What I Should Expect?
- HELP plz
- Silly Automatic Transmission Question/Problem
- Fluid change advice
- Overdrive off light blinks
- Want to drain all Fluid
- 12 of 14 Quarts
- Transmission fluid
- has any one had a shift kit installed in there truck?
- Tranny making odd noise in reverse
- Transfer Case Probs
- tranny grinding
- Clutch/Starter Safety Switch - How to Adjust?
- How to ID your Tranny
- Clutch Hydrolics
- 4X4 Problems HELP?????
- question, help!
- Do I need a shift kit or just reprogram my Superchip.
- Grinding/Vibration
- 97 Expedition stalls in reverse
- EMERGENCY HELP NEEDED!!
- Racing or High Performance Transmission Fluid
- how to get hydraulic lines off clutch slave?
- Transmission Control Indicator Light (TCIL)
- 4R100 vs 4R70W
- Weak transmissions?
- 5-speed accessories?
- Vibration
- Full time 4 wheel drive???
- 4R70W torque rating details
- HP vs STOCK TRANS.
- Front End Noise.
- "Clunking" from 4x2 to 4x4?
- 195 bucks for a tranny flush + tax
- transmissions
- Transgo or Baumann Engineering Shift Kit?
- Replacing F-150 Trannys?
- Tranny thump.
- What could this be???
- Tranny applications
- vvvvviiiiibbbbrrraaatttttiiiioooonnn !!!!!
- Short throw in an F150???
- 1989 F150 Lariat 4X4, Rough down shift
- Tell me about my 4R100 tranny please.
- passing gear
- Not shifting into passing gear
- Normal????
- Who has used Redline MTL in their 5 speed?
- $63.00 for Transmission Flush
- Can the 4th gear T/C lockup MPH be lowered?
- A question for you smart auto guys?
- 5 speed shifter removal???
- New Transgo Shift Kit
- Maximum speed for 4x4 shift?
- May ahve a 4R100 for sale, rebuilt
- 5 speed ,synthetic fluid and friction modifier
- Slipping Automatic--Try the Fix
- trans fluid, when to change?
- $New Transmission Price$
- Lockup T/C Operation
- Transmission/Transfer Case Fluid
- 5th gear transmission chatter/whine
- Loose clutch pedal
- clutch Goin out
- clutch Goin out
- How to make the tires "chirp" with passing gear
- 5-speed Slave Cylinder Failure,CentreForce Clutch Info
- Ford 5.4L Tranny and larger tires & wheels
- stock speedo gear?
- Transmission Windup?
- Can the shift firmness be reprogrammed in dealer land?
- Anyone running syn. ATF in 5-speed?
- What can this Tranny take?
- Clutch longevity
- Speedo Gear Location????
- Auto tranny shifting weird
- How do 456's do on the Highway with 35" tires
- Grease with needle fitting
- Slippp...ing Again/what's wrong?
- SuperCrew 5.4L Trasmission problems
- 2000 Expedition - Transmission Whine
- Which Transmission did I get?
- clutch or transmission making funny sound?
- test
- Manual 5th gear clunk! bad synchros
- Which transmission
- Synthetic tranny fluid. Is it worth it?
- '01 F150 Supercrew - Different Trannys on 4.6L and 5.4L?
- New Truck shifts slowly
- Transmission clunk
- question, help!
- Which Tranny, 4R70W or 4R100?
- Gear ratios
- Is my mechanic ripping me off?
- Manual Transmission Leak
- Transmission
- Service intervals
- Who make a performance clutch for a 98 4.2 ??Centreforce doesn't ,help
- 4R70W tranny drain plug pan
- Can you bleed a Clutch?
- Fluid Change
- tranny getting harder to shift
- New Art Carr Transmission
- Tranny Prob or not?
- Shutters and shifts hard, 2nd to 3rd & 3rd to 2nd
- '97 5sp seems to be "whining"???
- trans barely moves in drive ,must manually shift
- B&M Shift Plus
- Squeel from tranny in 1-2 shift
- Yank Torque Converters?
- LE Trans Fluid
- Tansmission Sticker found
- Slight surge when braking in O/D
- Tranny knocking? Torque conv.? Help!
- Tire size and towing
- Do i need to do anything to this Trans
- Shift Kit for 5-speed
- transmission
- Strange shifts on hard acceleration
- Won't shift from Park to Any Other Gear
- Transmission Bang
- '92 F150
- I think I fried my valve body
- what trans can it use
- 5 Speed Auto?
- 4.2L manual trans
- Is there A shift kit?
- Any known problems with 97 Lariat, 4.6L
- Inspection cover left off when new engine installed
- Noise when shifting from reverse to drive......
- slow speed OD slippage.slip yoke TSB a fix?
- Mounting Lights In Front Of Trans. Cooler.
- My Trans Broke!!
- Low trany fluid level from dealer!
- Reverse-to-Drive Tans Slip
- Aftermarket Shifter for 99 4.2??
- gear ratios
- some Q's about driving a manual
- Tranny Fluid Pan Drain Plug
- grinding in 4wd high
- Check your tranny cross bar member!
- 1998 4.2L Manual Tranny Change Interval
- Trans Temp (best Location)
- Any thoughts on More Trans Cooler?
- 95 F-250 4X4 EXT.
- Trann. Fluid
- 2001 5 speed...should I do anything to the tranny?
- 1997 Mercon V vs mercon
- Transfer case whine
- Shutter between 2nd and 3rd under normal Accel
- Transmission Studdering
- What is the best shift kit...please advise..
- 4.6L Manual Transmission Fluid Change
- Shifter anyone?
- Trans temps
- Trans pan
- Mercon V in early E4OD
- part # for Trans Pan Gasket & Filter
- auto popping out of second??
- Resonant noise @ ~1700 rpm reduced after determining TC stall speed.
- Need info on 5spd tranny
- High-stall torque converter good investment for acceleration?
- 2001 SuperCrew + Bad Transmission
- Draining The Torque Converter
- Manual Transmission Drainage
- Shifting Hard
- overdrive on/off
- Mobil 1 Synthetic ATF in 5sp?
- Chattering Tranny
- transmission popping
- Grinding Transmission
- Leaking differential, worry or not?
- TSB 98-8-8
- What's your torque converter's stall speed?
- SLIP YOKE TSB... WHERE TO FIND???
- TRANSMISSION
- OD Controll fuse keep blowing
- What's this plastic thingie rolling around in my trans pan?
- 5 spd whine on steep grades
- Speedo correction?
- auto. trans. identification
- Reverse light switch on SuperDuty 5 sp tranny
- 4.6 supercharger and transmission?
- tranny slippage
- Rand, the "slipping" feeling . . .
- shuttering trans
- Just another clunk (P to R back to P
- I have a (dumb) question about how the OD works.
- 30000 mile tranny change flush or pan drop
- Kansas City v. Norfolk
- Tran Fluid Change
- New Tranny Fluid or New Timing Chip?
- Coasting in Neutral with Manual Transmission
- Shift Kit, Torque converter, ect... What would be best??
- 1999 F150 AUTO TRANS HIGH REV.
- 2001 4R100 Failures - Stop Build
- Shift Kits and Warranty
- TRANSMISSION RELIABILITY
- Slush Box No More!!!
- Need to know what kind of tranny I have?
- "Slipping" feeling in tranny?
- Clutch Resevoire (How Full?)
- cruse control down shifting
- Transmission "lurching" during downshift
- Trans goin out??
- Trany. Shift Kit
- Drain Tube?
- 4 Wheel Low light not working?
- Intermittent delayed shifting out of 1st
- need tranny for '88 F150 4spd w/OD
- ELECTRONIC SHIFT ON FLY OR STICK
- Roaring from 0-15 mph
- What tranny fluid Should I use in my 5-speed???
