question, help!
ok i found a respectable dealership that is gonna do a complete tranny fluid change for 125 bucks..
my problem is this ford dealership does not know about synthetic tranny fluid either (starting to get worried) seems like nobody out here knows what I'm talking about..
I have a automatic v6 4.2 f150 xlt.. what do you guys recommend I pick up at the store?? The dealership obviously does'nt carry any synthetic fluids besides mobil 1 for the engine..
can you guys give me some advice?
Green and Brown
97 F150 XLT
V6 4.2L 4X4
12 disk cd changer, jvc 4ch 560watt poweramp (waitin on the speakers)
MODS :
K&n air filter
Superchip
Ravin Z55 exhaust
What's next?
still thinkin):
FIPK,Tornneu cover, Tinted Rear Window
TBS, Jacobs ignition system
Green and Brown
97 F150 XLT
V6 4.2L 4X4
MODS :
K&n air filter
Superchip
Ravin Z55 exhaust
What's next?
still thinkin):FIPK,Tornneu cover, Tinted Rear Window
Patrick,
I don't know which full synthetic trans fluids are compatible with your trans (meet Ford specs). The Ford Mercon V is a synthetic blend used on the '99 F150 models and later. From what I understand you can upgrade to this fluid for trans using Mercon III.
Why don't you request the dealer to use this trans fluid? Ask them to be sure.
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, HD electrical and cooling, power seat, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
You have a 4R70W transmission which requires a fluid meeting MERCON V specs. The Motorcraft fluid your dealer is likely to have is a synthetic blend.
If you do buy a different fluid make sure it says MERCON V.
MERCON V is a replacement for some, but not all applications using MERCON. For ecample, the E4OD and 4R100 used in some F150s cannot use MERCON V.
Mark
Mark
patrickjp - From what I've read Amsoil synthetic tranny fluid is supposed to be one of the best around and compatible with all Ford transmissions. I plan to drain mine soon and put the Amsoil in. I already use Amsoil 0W30 in my 4.6 and have not had any problems or used any at all (50K. You might look up Amsoil on the net at Amsoil.com and it will describe their products including tranny fluid. Good luck
97 F-150 Lariat, Leather, Ext. Cab
White/Champagne, 4.6L, Auto.
Tinted Windows/Bedmat
Toolbox/Lund Bug Deflector
Dual Exhaust
Grille Guard
Chrome bed rails
265/70/16 Goodyear Wrangler Rt/S
Dual Exhaust
Grille Guard
Chrome bed rails
thanks!
Green and Brown
97 F150 XLT
V6 4.2L 4X4
MODS :
K&n air filter
Superchip
Ravin Z55 exhaust
What's next?
still thinkin):
Green and Brown
97 F150 XLT
V6 4.2L 4X4
MODS :
K&n air filter
Superchip
Ravin Z55 exhaust
What's next?
