Do I need a shift kit or just reprogram my Superchip.
Old Dec 20, 2000 | 12:31 AM
LaserNAV's Avatar
Question Do I need a shift kit or just reprogram my Superchip.
Here is my problem I think.
On several occasions now when I have put my foot into it from a start. It launches just fine raps out just fine. Then when I get to about 5.5 KRPM (shift point between 1&2) My rev limiter kicks in before my shift can complete its transfer between 1 and 2.
1) Hits about 5.5 K
2) Transmission starts to shift.
3) Engine keeps wanting to go past rev limiter
4) Rev limiter it keeping it around 55. K
5) Transmission finally makes it transition between 1&2
Does any one else have this problem?
Is it a problem?
Can the superchip be re-programmed for quicker shifts or do I need to use a shift kit?
Seems to me that this time while I am limiting my power I would rather be launching.
2000 Navigator. Laser Red, Every option. , (DOHC) cams-32 valve Intech , (6) Bolt Mains, K&N FIPK , Superchip, True Duel Flowmaster 50 series. 2X SISO , vented out each side. Rear air deflector, Bug deflector, PIAA, headlights (SUPERWHITE)
Looking at Hitting 400 Hp without a blower. Using in addition, headers (If possible)
(Waiting for JBA to develope Headers)
“91” F150 4X4 Shorty “Ultimate Off Road Edition” Borge Warner T18 4 speed, Traction Lock Front and Rear Differentials., Smitty Built Duel Tube Roll Bar, Moog Super Off Road Coil Springs, Factory 2” Lift Rancho RS 9000 Shocks , Stock Front “QUAD SETUP” 33x12.5 (B.F. Goodrich) Mud Terrain Warn Winch Combo Bush Bar with Warn XD9000I Winch. Full Factory Skid Plates. 302 Long Block, K&N FIPK JBA Chrome Headers, Custom Catback using Flowmaster Muffler, Duel out side behind rear wheel.
Old Dec 20, 2000 | 12:52 AM
Neal's Avatar
Post
HI!... LASERNAV : By any chance have you changed to lower gears? I had the exact same problem after I installed 4.10 gears in my truck. At the dragstrip or when on the street, if I floored it from a stop and left it in drive it would hit the rev limiter during the 1ST - 2ND. This would cause my truck to fall on it's face BIGTIME! It would almost feel like it would stall. The solution is to call MIKE TROYER and have him fix your problem with the superchip. MIKE had SUPERCHIP's raise my rev limiter by a couple hundred rpm. This way it won't hit the rev limiter anymore. Now on my new custom "FLIPCHIP" I had MIKE raise my 1ST gear shift point to 5800RPM and raise the rev limiter to 6000RPM. I also had him raise my 2ND gear shift by 200RPM. Hope this helps you out. Do yourself a favour and give MIKE TROYER a call.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Dec 20, 2000 | 12:54 AM
LaserNAV's Avatar
Talking
Thanks Neal.
You Rock with all your Knowledge about this stuff.
