Front End Noise.
I have been running my truck for about 5 months now on and off road. It has preformed well, I put on a set of BFG M/T and now it is better yet.
Then comes the first major snow fall of the year 1' in 12 hours. Cooooool, eh! Not quite, because at the time when I need it the most my front end starts to make some wierd noises.
Symptoms:
Only notice the noise in 4wd(hi and lo).
Front right auto locking hub was warm, not hot, just warm.
The sound seems to be coming from the left(?)
Noticed small scratches on the inside of the right rim(brand new I might add) just where the lip is for the tire bead to set.
Happens all the time when in 4wd.
Starts to shake like a MF when you hit about 40mph.
I need help, the ford dealerships are quite busy and have quoted me at least a 5 day turnaround.
Symptoms:
That sounds bad.The shaking like a MF occured in 4H? Going that fast in 4L can cause violent shaking.If it was in 4 H you have got bad news something in the front part of the 4x4 is broken.Oh, I just remembered something. One of my dads friends bought a brand new F150 4x4 and took it out to the woods the following weekend.Shifted into 4H and the thing started bucking and shaking like crazy.Turns out ford "accidentally" put the 3.55 gear in the front and the 4.10 in the rear.Boy was he mad.But it got fixed and all is good.Hope this helps in some way.
2000 f150 4x4 sport,black, 3.55 5spd ,4.2 liters of fury ----mods----
stereo,pioneer cd,cadance ultradrive amps,alpine 12 sub,eclipse mids&tweetsAppearance: profile bug guard,smoked headlight covers,Gts tailblazerII taillight covers painted to match truck,blue cargo lights,chrome exhaust tipFunctional:265/75 pirelli scorpion at,cranked torsion bars,black Delta tool box,valley towing class III reciever hitch,herculiner bed liner,taz floor mats Performance: Jet reusable air filter,modified airbox(crash1style)Coming Soon
supercharger, jba headers,throttle body spacer,ravin cat back,superchips
Come on guys/gals, please help. I have about 2' of snow now to play in and cannot because the ford shops are busy, and cannot see me until next week. Any advice or tips will be helpfull.
This really belongs in "Other Drivetrain".
You never did describe the noise, 88 Bronc.
For a 12 year old Bronco, when was the last time that:
The front driveshaft U joints were checked?
The left and right stub axle U joints checked?
The Right axle shaft intermediate U joint?
The Right axle shaft slip joint cleaned and regreased?
The pilot bearings that are INSIDE each spindle, cleaned, inspected, regreased?
Front differential oil level checked?
And Autohubs cleaned and regreased, if you have them.
There are a lot of pieces in a Dana 4WD setup that need to be maintained for it to work well. And not a good time of the year to work on one outside!
If you descibe the sound you hear, and more detail on when you hear it, we might be able to help.
[This message has been edited by Granpa (edited 12-16-2000).]
I have to say that I like the "MF" description. I will guess that's a very technical matter.
Anyway, I hope that by this time you are on the right track to get it fixed.
Good luck.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Gibson Supertruck, Stepshield door sill protectors, Performance Accesories 3" Body Lift, Superlift 3" lift blocks, Lift Lips, Gabriel Gas Ryder LT VST Shocks, Daystar Front Anti-sway Bar Polyurethane Bushings, Heckethorn Steering Stabilizer and 35x12.5R16.5LT BFG All Terrain KO's on 16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Good luck.
Hey, guys.
Grampa, you were right, it was the rear universal on the front axel, that was causeing the problem, thanks.
It is fixed.
Sorry for posting on the wrong topic.
It is fixed.
