Lockup T/C Operation
Old Nov 27, 2000 | 05:50 PM
DAVID C's Avatar
Question Lockup T/C Operation
I'm trying to figure out what's wrong with my torque converter operation. It appears that over 40 mph, my torque converter locks up within 1 second of upshifting, or downshifting if the throttle is over half way depressed. Is this functioning correctly? Also, at a steady cruising speed (over 45), if I touch the brake pedal, the T/C unlocks for only 1 second. Shouldn't it stay unlocked until the brake is released (like GMs)? I hate to bring it to the dealer, only to find out it's normal. My local dealer doesn't know $#!t and can't be trusted. TIA. Dave C.
'97 F-250 LD 3dr 4x4 5.4 (toy hauler). '86 Buick Grand National 3.8 SFI Intercooled Turbo V-6 (wifes summer toy). '87 Buick Turbo-T 3.8 SFI Intercooled Turbo V-6 (my summer driver/weekend racer. Nearly stock, 12.3 @ 111mph)
Old Nov 29, 2000 | 11:51 AM
birdman's Avatar
Post
Having the TC lockup early after the shift is preferred to get better mileage. The TC unlock with braking is to not have the extra torque going to the wheels. If you stay in the brake it should stay unlocked. This sounds like normal operation, but you could also check www.alldata.com for TSBs regarding it.
birdman
Old Dec 1, 2000 | 10:56 AM
DAVID C's Avatar
Post
birdman, you're right. I had a ford tech hook the computer up. We took it for a ride. I was very impressed with the test programs the unit offered. It tested fine. He was telling me the throttle position, speed, rpms, what gear I was in and torque converter engagement points. He did say Ford wants the t/c engaged as much as possible to reduce temperature and increase fuel mileage. I still have 2 concerns about the t/c that I forgot to ask him about. 1) t/c does not STAY disengaged when the brake pedal is depressed. 2) When floored, t/c locks up mid way through 2nd gear (~3500 rpms). Is this correct for my EOD4?
Old Dec 1, 2000 | 03:25 PM
Mark Kovalsky's Avatar
Post
That is the correct operation for your E4OD.
Mark
Old Dec 3, 2000 | 06:25 AM
DAVID C's Avatar
Thumbs up
Thanks Mark. I'm used to my '89 GMC (Gotta' Mechanic Comin'... General Mess of Crap..ect, ). Dave C.
