Gears
Old Dec 28, 2000 | 05:31 PM
mustangjay's Avatar
Question Gears
I have a mustang, but i wanted to buy my brother some gears for his 2001 F-150. I know with mustangs you only need to buy one set of gears to change the ratio. My brothers truck is a 4X4, so do i need to buy two sets of gears for him, or just buy one set? Thanks
Old Dec 28, 2000 | 06:13 PM
98fword's Avatar
Post
mustangjay,
I would have been happy for someone to have bought one of the two sets for me when I had the swap done on mine. But if he's going to do a gear change on a 4X4, he'll need both sets.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, Superchip, Gibson single cat-back, 80/100w German head lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, 285/75R16 Goodyear MT/R's, 16x8 Center Line Hell Cats. Needs one more door.
http://hometown.aol.com/ninetyeightfword
Old Dec 28, 2000 | 08:01 PM
max mitchell's Avatar
Cool
You may want to find out the total cost of the project also: gears, parts, and labor (in your area). It's nice to know this on a 4X4 beforehand, so your jaw does not hit the floor. Just Kidding, Good Luck !!
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Dec 29, 2000 | 05:04 PM
mustangjay's Avatar
Smile
Thanks for the help guys Also i wanted to know how you like your 4.10's? I have 3.73's in my mustang and i love them, but i was thinking in a bigger truck 4.10's would be better.
Old Dec 30, 2000 | 01:43 AM
jgorka's Avatar
Post
To get an idea of how that translates from your car to your truck you need to figure out the percentage change of the tire size change, then apply that percentage to your car's axle ratio.
For example, if your car's tire diameter is 27.25 inches -- and your truck's tire diameter is 30 inches -- the ratio of tire size is 30/27.25=1.1 -- so you must multiply your car's 3.73x1.1= 4.10 to keep the same ratio that you're accustomed to with your car.
Y2K™ 7700 4x4
Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old Jan 2, 2001 | 02:43 PM
JMC's Avatar
JMC
25 Year Member
Post
mustangjay,
Just one word of caution, the gears for the front are reverse cut. The front differential is a flipped 8.8 from the Lincoln. The trucks also use a 31 spline axle.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
[This message has been edited by JMC (edited 01-02-2001).]
Old Jan 3, 2001 | 11:58 AM
captainoblivious's Avatar
Post
Those gear changes in 4x4's are expensive. Has anyone done a gear change themselves or is to hard?
I would almost rather pay someone to change the gears is my manual tranny over rear-end gear ratio's.
