Speedo Gear Location????
Old Nov 17, 2000 | 01:56 PM
JMTruck's Avatar
Question Speedo Gear Location????
Today or tomorrow I will be replacing the stock speedo gear. I want to go directly to the point. Where is it located, exactly?
Thank you in advance for your help.
Old Nov 17, 2000 | 03:08 PM
jackhel's Avatar
Post
Depending on your transmission. If you have the 4R70W (AODE) the speedo gear is located on the driver's side of the tranny, if you were looking at it, it's going to be close to the driveshaft. It should be a small black connector about 3-4 inches long sticking out of the side that connects to the wiring harness. It's held in place by one small bolt. Once you've taken it out, just use a small screwdriver to remove the retainer ring, slide off old speedo gear, put new gear on, put retainer back on, and that basically all there is to it. I don't know if this is the same with the E40D. Hope this helps.
98 Nascar Edition
Homepage (Needs Updating)
Powerdyne Supercharger w/9psi, Superchip, Autometer Boost Gauge and Pod, K&N Filter, TransGo Performance Shift Kit, 295/65-16 Eagle GTII Tires, Flowmaster 40 series exhaust, Taylor 8mm wires And Bosch Plantinum Spark Plugs, TPS Mod, Gutted MAF, 4.10 Rear End Gears, XTRA Bright Halogen Lights, Amsoil Series 2000 Synthetic 0w-30 Motor Oil, Tinted Windows, Belltech 2 inch rear drop, G-Tech Pro Series II, Bedliner, 100w driving lights, Aftermarket stereo stuff w/ custom bandpass box, Cobra 75WXST CB Radio, Little Wilson Antenna, and some other stuff I can’t remember
[This message has been edited by jackhel (edited 11-17-2000).]
Old Nov 17, 2000 | 09:06 PM
JMTruck's Avatar
Post
jackhel
Thank you very much. I have the E4OD, but I think if it is not in the same place you mentioned, it's going to be close.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips, Gabriel Gas Ryder LT VST Shocks, Daystar front anti-sway bar polyurethane bushings and 35x12.5R16.5LT BFG All Terrain KO's on 16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Old Nov 17, 2000 | 10:07 PM
Factory_Tech's Avatar
Post
If it's an E4OD it's on the extension housing, but I don't remeber what year it was, the 4R100 (E4OD) doesn't have a speedo gear after the 97 or 98 Model year, depending on the model, they went to a OSS (Output Shaft Sensor) and tone wheel, which is an electronic replacement for the speedo gear.
G
Old Nov 18, 2000 | 11:03 AM
JMTruck's Avatar
Post
Yes, that change was after the 97 and 98 models. So, I hope everything is going to be OK and I will find the location for the new replacement.
Old Nov 18, 2000 | 05:34 PM
StrangeRanger's Avatar
Post
There's no speedo gear in my '96 E40D. It uses a VSS in the diferential housing. Did they go back to a gear with the '97s?
Old Nov 18, 2000 | 11:18 PM
JMTruck's Avatar
Post
Yes, those years got speedo gears.
Old Nov 19, 2000 | 05:35 PM
Post
Well, it's just a nomenclature thing, but we call the forward sensor the TSS Turbine Speed Sensor and the rear one the OSS, they're actually the same part unless you have a PTO option, and they switched over the course of several years depending on the model, I don't remember which year they switched each model, the vans still get a speedo gear on some models, I think all the 7 gears are DSO model vans. some of them have them on the transfer case, some are on the extrension housing, we don't install the transfer case, that's done at the assembly plant.
G
Old Nov 19, 2000 | 06:06 PM
JMTruck's Avatar
Post
I bought my 17T gear yesterday for $9.00. It is the green one for the automatic transmission in the 98 model. It was located in the top side of the transmission tail inside of a black connector.
