How to make the tires "chirp" with passing gear
Old Nov 22, 2000 | 09:12 PM
Spanky114's Avatar
Question How to make the tires "chirp" with passing gear
Hear of a lot of F-150's "chirping" the tires when passing gear hits.....Best way to do this would be? Or is this something that would best left alone for the sake of a transmission's life? Any input would be appreciated.
Old Nov 23, 2000 | 11:17 AM
Throttljock's Avatar
Registered User
Post
Go buy yourself a superchip. they modify the shift points and increase the firmness. I assume you have an auto. you will surely get a chirp on a 2-1 shift and most likely on the 3-2 shift if you have the 5.4.
2000 XLT SC FS, 4.6/5-spd, 3.55 LS, 4X4 Off-Road, Black w/silver 2-tone. Pro-chamber Cat-back exhaust, K&N Filter, Bugflector, Cowl cover, Window shades, Carbon fiber headlight covers.
Old Nov 23, 2000 | 11:36 AM
max mitchell's Avatar
Cool
Mine chirps 2nd shifted manually, after the chip. I'm from the old school, so I'm gonna get a shift kit after the trans proves itself, and the warranty expires.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, K&N oil filter, K&N F.I.P.K., Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
Old Nov 23, 2000 | 06:03 PM
Spanky114's Avatar
Post
Almost forgot, automatic 4.6L on my truck. Was looking for options other than a Superchip - premium gas prices are way too high to support that change. Kinda looking at options like tranny kits or similar.
Old Nov 23, 2000 | 06:24 PM
JMC's Avatar
JMC
25 Year Member
Post
Spanky114,
Good luck chirping 3rd with a 4.6L.
It is going to take more torque than you can produce stock unless you have skinny tires and one wheel peel.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Nov 23, 2000 | 10:37 PM
Cool
Spanky114- "options other than a Superchip" = a good shift kit (transmission valve body reprogramming).
Old Nov 24, 2000 | 02:03 PM
Former Sponsor
Post
Hi Spanky114,
A shift kit may get you what you are looking for, if you don't want to use the Superchip.
We like the Transgo shift kits, they work well and have several levels of firmness you can set them up for. You'll have to set it to at least level 2 if you want to actually "chirp" the tires on the full-throttle 1-2 upshift.
Best of luck whatever you decide!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Nov 24, 2000 | 04:04 PM
Kenster's Avatar
Post
Spanky114 say:
_________________________________________
My first thought is...WHY would you want to do this? Spend a lot of money on something so you can tear up your tranny and wear out your tires to make a little tiny bitty noise that will impress no one?
Old Nov 24, 2000 | 09:16 PM
Cool
Laying a 2nd gear scratch A)does not cost alot of money B)does not tear up your transmission (firm shifts improve transmission life) C)does not cause noticeable tire wear. If you wonder why someone would like to do this, you probably wouldn't understand. Fast cars commonly do this, have for decades; I have also seen a few impressions made. I'm just playing around, but it has been fun over the years in many cool muscle & performance cars, etc...LOL. Even funner with a manual trans.
Old Nov 24, 2000 | 11:01 PM
Registered User
Post
sorry Kenster, i gotta tell you that you sound like my mother. our boy here asked how to make noise, not ways to go slow...
Old Nov 25, 2000 | 09:05 PM
Spanky114's Avatar
Thumbs up
Yeah Max, "impressive" - thats what I was looking for. Looks like some different opinions are in place. Transgo sounds interesting, from what I have read - where to buy though? Thanks for your input
Old Nov 25, 2000 | 10:15 PM
Cool
Spanky114- Several brands of shift kits (Transgo,B&M,Baumann,etc.) can be purchased at most any performance parts retailer (Jegs,Summit,PAW,etc.). Each of these mfgrs and retailers have very informative websites. Most transmissions shops install and stock/order shift kits also. Good Luck !!
Old Nov 28, 2000 | 04:06 PM
Silver Y2K
Guest
Posts: n/a
Cool
I have chirped 3rd quite a few times in both a 4.2L and a 4.6L. Both with manual trannys, though.
Y2K XLT Flareside
Sport Package
4.6L V8
5-Speed
3.55
Flowmaster
A.R.E. "Lowrider" Fiberglass Tonneau
Superchip
Old Nov 28, 2000 | 04:27 PM
LaserNAV's Avatar
Talking
I got my first passing gear scratch the other day. Caught me by total surprise. I went to pass at around 45 MPH, I laid into it ... it shifted down WOOHOO. Front drive kicked in pretty damn quick though. (AWD)
I would love to have a car that did a scratch on every shift. I guess I am an old timer muscle car guy.
I am more worried about my transfer case slapping in the front drive on every heavy footed take off.
2000 Navigator. Laser Red, Every option. , (DOHC) cams-32 valve Intech , (6) Bolt Mains, K&N FIPK , Superchip, True Duel Flowmaster 50 series. 2X SISO , vented out each side. Rear air deflector, Bug deflector, PIAA, headlights (SUPERWHITE)
Looking at Hitting 400 Hp without a blower. Using in addition, headers (If possible)
(Waiting for JBA to develope Headers)
“91” F150 4X4 Shorty “Ultimate Off Road Edition” Borge Warner T18 4 speed, Traction Lock Front and Rear Differentials., Smitty Built Duel Tube Roll Bar, Moog Super Off Road Coil Springs, Factory 2” Lift Rancho RS 9000 Shocks , Stock Front “QUAD SETUP” 33x12.5 (B.F. Goodrich) Mud Terrain Warn Winch Combo Bush Bar with Warn XD9000I Winch. Full Factory Skid Plates. 302 Long Block, K&N FIPK JBA Chrome Headers, Custom Catback using Flowmaster Muffler, Duel out side behind rear wheel.
