View Full Version : Engine
  1. Any notorious 4.2 or 4.6 L problems?
  2. Gatorback belt won't fit?!?!?!?
  3. Help! Do I have an MAF sensor?
  4. TPS problem?
  5. My 93 Supercab Leakes Water Sometimes
  6. Restore?
  7. Customizing My Intake On My 1993 F150
  8. Hi Idle After Stopping w/ Air On
  9. electric fan ???
  10. What is the average life of an alternator?
  11. Torque & Power Curves
  12. '90 F-150 4.9
  13. antifreeze
  14. OT Mustang Question
  15. Ethanol blend? good or bad
  16. 1st Oil Change...
  17. Engine just sht down at light
  18. Amsoil XL7500 not synthetic?
  19. Changing Plug Wires
  20. '94 5.0L Crate Engine????
  21. Autolite Platinum Plug 4.6 L AP764
  22. TB & Intake spacers?
  23. Ignition key is $100 ???
  24. Will A 2002 Overhead Digital Console Work In My 99 F-150??????????
  25. oil on spark plug thread bad???
  26. Truck Dies
  27. Interesting 5.4 Gas mileage.
  28. 92 f150 4.9 distributor change help
  29. F-150 Vs. Chevy
  30. SES Light and Test Codes
  31. New head & mpg loss
  32. fuel injector cleaner/coil paks
  33. Auto-Rx and Amsoil
  34. Gearing (did not know where to put this one)
  35. Cobra R Waterpumps?
  36. K&N vs. others (oil filters)
  37. Has any one cut the centerpost from their MAF sensor?
  38. Temp sensor
  39. Oil Level Question
  40. engine light -- EGR
  41. Dohc
  42. Service Engine Soon Light Came on
  43. missing or jerking what could it be???
  44. Hesitation
  45. Quick Question
  46. 130k and starting to become sluggish
  47. 4 piece oil pan gasket on 90 302
  48. oil analysis
  49. PCM Update
  50. MAF on '94 5.8?
  51. Freeing-up H.P. vs. Adding H.P.?!!
  52. What Water Temp. is Optimal For a 4.6 V8?
  53. failed connecting rods
  54. 4.6 to 5.4
  55. 04 engines, 5.4L
  56. Transmission Fluid
  57. What PSI should I be reading on my soon to be installed mech oil pressure gauge?
  58. EGR Valve Leaking?
  59. Cleaning under the hood
  60. Engine repair etiquette-New or ReMan?
  61. Pulling codes
  62. installing serpentine belt on '98 4.6 engine
  63. Wife keeps setting off check engine
  64. Causes for Check Engine Light
  65. Oil Recommendation
  66. Need website for the Air Force 1 intake....
  67. If its not one thing its another
  68. Tek Question
  69. Burping sound from gas cap?
  70. hissing when engine shuts off
  71. '94 5.8 Shudder
  72. tailgate locks on its own
  73. Question about 351 M 400
  74. OBDScan for Palm or Visor
  75. Does your truck shock you??
  76. Help, I can't get home!!!!!!
  77. Overheating, need fan?
  78. 2002 Piston Slap?
  79. cylinder head
  80. Hesitation while accelerating
  81. Is the 4.6L Enough Engine???
  82. Royal Purple ??? Looking for Data@!
  83. Check Engine Light on a 98
  84. how to remove oil filter?????
  85. Cleaning throttle body helped?!?
  86. Check Engine warning
  87. Fans/Pulley & Timing Chain Question
  88. Do I have piston slap?
  89. Part #...Please help!!!
  90. Off topic--91 Lasabre-gas mileage mystery
  91. smoking 4.6, dealer stumped!
  92. Increase Your Fuel Mileage By 27.4% ?
  93. F/S - 5.0L HO Race/Street Engine
  94. Edelbrock or BBK TB's
  95. Squeeky belt?
  96. Hard starting 5.4L
  97. Pics of K&N FIPK install on a 4.6L
  98. Who knows their F150 tensioners?
  99. Engine Rebuild Manual
  100. 4.6 truck vs mustang cylinder head differences.
  101. HELP! Washed engine and WONT STAY RUNNING!
  102. Check Engine Light - P0401
  103. error code
  104. switched oil-got leak
  105. Under Drive Pulley Installation
  106. 94 Lightning 393 stroker
  107. Tick Tick Tick - On Cold start Solved
  108. Engine Runs rough when it rains
  109. Engine runs rough when it rains
  110. Changed air filter = Service Engine light?
  111. Just calculated my MPG...
  112. Problem starting after engine warms up
  113. OEM Oxygen Sensor or Bosch?
  114. Engine Exchange Shops
  115. 5.4 Triton Throttle Body Cover
  116. New oil filter didn't stop the rapping
  117. Is resetting the computer a good idea?
  118. Lightning gas mileage!
  119. Low speed hesitation misfire choking
  120. Oily gunk in my TB! How do I clean it?
  121. need to change the valve cover gasket on my 88 F150 300
  122. Pulls strong to 5000 then.......
  123. Engine Recall 97-98 V8 engines?
  124. My 99 F-150 4x4 is Sick (misfiring). Need Help ASAP!
  125. What to do? New engine or replace parts?
  126. newB with a mileage question...
  127. Diesel In Gas Engine
  128. Gas Mileage same in City and Interstate?
  129. Rough Idle, Red deposits on plugs?
  130. What do these codes mean what should i change
  131. New 3.9L engine coming out
  132. Rapping noise for first 30 seconds
  133. Engine misfiring i think
  134. Sinnals not working when steering wheel is tilted down,HELP!
  135. Mpg
  136. starter problem
  137. replacing heater core hoses
  138. Synthetic oil at 75K?
  139. CEL Code PO#442 Cheap Fix
  140. 4.6L Stroker
  141. Longest thread, what's your mpg this tank?
  142. PLEASE HELP! Cannot remove starter!
  143. aftermarket idler pulley?
  144. how do you tell what gear ratio by vin # ?
  145. My '03 Ticks
  146. Need HELP ,verifing Vin # info
  147. Newbie to the F-150, Gas mileage ?'s
  148. lean codes bank 1 & 2 ?
  149. Premium Gas vs Regular Gas
  150. engine problems
  151. Oil Additives Good Or Junk?
  152. Heater Core replacement under warranty
  153. Gvwr
  154. Air Conditioner (Ford Ranger '98 2.5L)
  155. Fancy hose clamps...
  156. 97 5.4L Spark Plugs???
  157. Too late for Synthetic or what???
  158. Oil Cap GOOOOOO
  159. Not a Ford, but if you can help out a fellow member....
  160. Max Speed and Power
  161. 86 or 88 Octane
  162. Engine Vibration
  163. Need Help!
  164. Misfire Question
  165. SUPER CHARGER on stock 5.4
  166. GVWR codes
  167. Can anyone tell me
  168. Very Odd. Magic RPM Drop.
  169. must be a easyer way
  170. Oil Filter Placement
  171. High Mile 5.4L
  172. 4.6 block
  173. Pinging only getting worse
  174. How hot to damage the engine ??
  175. Question
  176. TO All SERPENTINE BELT ON 2OO3 LOOK HERE
  177. EBAY Ford Manuals
  178. Plug Wires @ 65,000
  179. GY belt part#
  180. Assembly date
  181. check out this website
  182. Oil Foam, Coolant Leak, Misfire On No. 6
  183. Hypertech broke my truck!!!!
  184. Roushfan? JLP intake?
  185. Superchargers
  186. Flex-Fan
  187. wheel bearing repacking?
  188. noobie question about vacuum
  189. Polyurethane motor and trans mounts...
  190. Running Poorly - EVAP Fail
  191. 01 4.2 help
  192. ram air mod
  193. Doesn't anyone here know if the 2001 5.4 have the coolant hose leak problem?
  194. Gatorback belt for 02 f-150
  195. Plug Gap ?
  196. Saw the new 2004 F150
  197. Pulleys??
  198. obd2 code 1131
  199. How Much oil pressure in a 5.4???
  200. Rear Main Seal
  201. Do the 2001 5.4 have the coolant hose leak problem?
  202. won't start
  203. using 5W-20 in the new Ford engines
  204. Ford Technical Hotline
  205. Almost 70K. Replace O2 sensors yet for better mileage?
  206. Manufacturer info for a 4.6
  207. Underdrive Pulley
  208. Won't start
  209. Cyl. #3 plug wire keeps popping off
  210. Can any one help me remove airbag?
  211. Hose clamps over cylinder question.
  212. War...Politics
  213. vehicle computers
  214. What GCWR 92 F150 Supercab
  215. Strange water leak in the cab, any ideas?
  216. 5.4 is a dog of line help!
  217. EGR-how do you clean it?
  218. What is the redline for my 5.4L
  219. Revised HP/TQ numbers for all engines
  220. Head gasket leaks
  221. 96-98 4.6 Mustang/T-BIRD Underdrive Pulley
  222. Engine just started missing
  223. 5.8 Litre gas mileage
  224. What sensor do I need? (cylinder head)
  225. Help! How do I replace heater core on 98 F150?
  226. Baby Diesel back on track?
  227. High Pitched Whine at cruising speed.
  228. West Coasters...Best Gas For 5.4 With Microtuner?
  229. Plug Boots
  230. dyno'd the truck today
  231. Bosh PLus 4
  232. Won't start...any advice appreciated.
  233. Amsoil dual remote oil filter - Supercrew 4x4
  234. Which is better FIPK
  235. gas differance
  236. Loud hum at idle when cold
  237. Does dealer fix piston slap
  238. Horsepower/Torque for all engines here.
  239. horsepower rating/towing
  240. Denso Iridium Spark Plugs
  241. 5.4L Noise?
  242. Vacuum Hose Size/ Brake Booster Lines
  243. For those who cleaned their MAF, a ?
  244. How Much HP Gain With Microtuner, AF1, & Magnaflow CB?
  245. Oil is pissing out the back of the heads!!!
  246. 4.6 to 5.4 swap questions
  247. Rough idle - CEL
  248. codes p0171&p0174?
  249. Dyno results
  250. want more power!!!!
