Overdrive
Old Jul 23, 2006 | 01:38 AM
blackf150337's Avatar
Overdrive
Anyone with a 04+ go wide open thottle with overdrive off? I've done it a couple of times and it makes me get up pretty damn quick... I can smoke any chevy 5.3 and i have 20's and 35's with stock gears..... goin full throttle with OD off bad?
Old Jul 23, 2006 | 02:27 AM
itimebomb89's Avatar
2000 f150
I do it all the time it hasent caused me any problems i use it for passing
its just a larger gear in the transmission designed to drop the rpm's at cruising speeds for fuel economy but after 70 mph it hops over 3rd gear and goes streight to overdrive
try shutting it off on the freeway doing about 70 then floor it and let it show u what that triton is capable of
Old Jul 23, 2006 | 12:25 PM
adrianspeeder's Avatar
Ummm, no. The only change lockin out overdrive is the tranny shifts between 1-2-3 instead of 1-2-3-4.
Adrianspeeder
