Engine cooling and oil filter relocation questions
So I've looked into electric fans(including all the posts about em on here), and electric water pumps.
Afterwards, I've got a few questions..........
Why is the F150 dual 16" fan setup around $400?!?! what would be different from me buyin 2 16" 2500CFM fans for $240, and a wiring harness for $60 and makin out for $100 cheaper?
approx. how many CFM does the stock water pump driven fan move on a 2006 V6?
does anyone make an electric water pump for my 06 V6, or would I have to get an inline one?
and if i did get an inline one, does anyone make an adapter for the water pump spot on the block, or would i have to make the water pump a dummy one by taking off the pulley? and if i took off the pulley, is there a serpentine belt out there that would fit? i have A/C & power steering so could i get a belt for my truck without A/C or somethin?
now for the oil questions:
im also looking into oil filter relocation kits and throwing in a cooler as well, and MAYBE makin it a dual filter setup(probably not, but throwin idea around).
does anyone have an oil cooler installed, and if so, does your engine run noticeably cooler?
