Thoughts on Engine Cleaning
I am getting ready to replace coil packs, injectors and plugs. What are some thoughts on doing a conservative engine clean the night before I do the job and air blowing all the water out of the crevices after spraying? "No direct pressure spray of course".
when i clean my engine out i put tin foil over the potentially harmful components, or anything that looks like it could be and spray some simple green all over it and take a water hose with low pressure and rinse it off. Simple green usually does a good job unless you have some permanant stains in there.
Originally Posted by adrianspeeder
While I do clean the pushrod motors, the 4.6L still has all the factory dirt due to in my opinion too much electronics to wash.
Adrianspeeder
Adrianspeeder
rofl factory dirt i like that one
