indy coil code question
Old Jul 31, 2006 | 07:02 AM
jamison's Avatar
i have an 01 f150,4.6L,4x4,aod,my question is,the codes on my coils end with AA,when i look up an interchange on the computer at the junkyard that i work at,it says that they should be interchangeable with a 99 expedition with a 5.4L.problem is,their codes end with AB.i know duel cam 4.6L engines coils end with AW and won't work,but what about the AB ones,maybe if i switch them all.also,whats an easier way to find the quiter then just switching one and goin for a ride and movin it to the next hole.
thanks
Old Aug 2, 2006 | 06:59 AM
jamison's Avatar
come on,nobody knows.
Old Aug 2, 2006 | 11:55 AM
DaWG of Indpls's Avatar
Not me.
Old Aug 3, 2006 | 06:30 AM
jamison's Avatar
thanks anyway dawg
Old Aug 3, 2006 | 06:52 AM
Johngs's Avatar
They should exchange just fine, FoMoCo has several part numbers for the same part. The coils are one of the most obvious examples of this. Some have a green top, some have a yellow top, but thats about as far as the differences go.
Switching the coils one at a time is about your best option unless you want to spend the money on replacing all 8 coils....
Old Aug 6, 2006 | 10:54 AM
jamison's Avatar
thank you
Old Nov 22, 2006 | 06:59 PM
jamison's Avatar
so i found out that it does make a difference.it depends on which windsor you have.the aa or the ab.the difference in coils is there is a little lip on the inside of the ab coils that if need be,you can grind down.but for 40 bucks at pep boys,who cares.
