v8 swap
v8 swap
What all would I need to swap a 2005 mustang v8 into a 1997 v6 f150. I know I would need:
Custom engine mounts
engine
new transmission
driveshaft
computer
What else would I need to make this work.
All help is greatly appreciated.
engine
new transmission
driveshaft
computer
engine
new transmission
driveshaft
computer
engine
new transmission
driveshaft
computer
Your existing transmission would bolt up
driveshaft would be the same
computer would be a nightmare
the 2005 and up mustang 4.6L 3valve top end is radically different from a 2 valve 4.6L. Your computer could not run the variable valve timing. Thats a big part of what makes the 3 valve engines have such higher power outputs. the 05 mustang computer is also incapable of running the 4r70w transmission that is in your truck. The 05 mustang comes with a 5 speed manual or a 5 speed automatic, which by the way that 5 speed auto from what i understand is complete junk. then get into the nightmare of wiring. you could not use the harness from either vehicle. You would have to have an indepth knowledge of both wireing harneses and make your own using what you need from both harnesses. Not to mention there is no truck manifold for the 4.6L 3valve. All in all it's not worth the effort. For alot less money you could build on kick a$$ 2v engine and have plenty money left over for a blower.
Originally Posted by The Flow-Master
You will need to think about killing the low end on your truck. It will be a dog off the line. Maybe that's what you planned, but I just thought I would say that in case you didn't.
I have an '05 Mustang GT with the V8. Kick butt engine. I was recently in the dealership and happened to pick up a new vehicle brochure for the '07 F-150. Now, I only casually glanced through it, but I believe the '07 will be available with the 3-valve variable timing engine. Is that right?
Originally Posted by 5.8 liters
u would need custom engine mounts, the mustang blocks, headers, computer, heads, wiring harness, and all the wiring, and some other stuff, trannny
Originally Posted by MGDfan
Hi.
Where have you guys been?
The 5.4's in the F150 have all been 3V VCT engines since 2004
Thanks for all the info on the subject. I was asking because I could get that engine cheap. But it seems that the wiring would be hell. I could also get a 4.6L f150 engine out of an 02 or 03 f150 would that be a better choice? Do those engines come with the P.I. heads and intake. And how about horsepower and torque #'s if you please.
Again, all help is greatly appreciated.
If you are going to swap to a V8 by far the best bang for the buck will be the 5.4. You will need a tranny as the V6 tranny will not bolt up. You will need the PCM and complete harness to make things work. Find a 99+ 5.4 so you get the benifit of the Pi heads. if you decide to go through with it let me know and I can suggest what will be needed.
JMC
JMC
after all is said and done it would not be quick and easy or even cheap for that matter.
i saw a '98 f150 flareside on ebay a few months ago with one of these in it
http://www.fordracingparts.com/parts...tKeyField=9287
all it needs is 12v, fuel line and a few other basic parts but nothing major. most of the parts you might need to add to get this to work in your truck would be pretty cheap at an auto wrecker.
http://cgi.ebay.com/ebaymotors/1998-...QQcmdZViewItem
