0174 code
Old Jul 16, 2006 | 08:18 PM
Big 4x4s's Avatar
0174 code
has any body had a problem with this code if you have can you tell me how to fix it i would appreciate it
Old Jul 17, 2006 | 04:01 AM
Sparky604's Avatar
http://www.obd-codes.com/trouble_cod...gen-sensor.php
start with cleaning the maf sensor.
http://www.fordf150.net/howto/clean-...low-sensor.php
Old Jul 17, 2006 | 11:21 AM
chester8420's Avatar
Do what sparky says, and check for vacuum leaks. Bad ones will make a whistle. PCV valve hose boots are notorious for rotting off. Spray starting fluid around suspected areas if you can't reach them. Listen carefully for engine RPMs to change.
