View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 92 w/302, whats this wire go to???
  2. Engine Horsepower
  3. 1994 f150
  4. Negative battery cable question
  5. School me on engines
  6. just saying hello
  7. 96 F-150 OEM Frame Coating?
  8. Duel Fuel (87) Problem: Isolating Issue
  9. Gauges for an 83
  10. 1990 F150 fuse question
  11. Kenne Bell supercharger
  12. MPG from a 93 F150 4WD auto??Weak and sucks fuel!
  13. No tail lights
  14. Abs And Brake Light On
  15. Someone please help with a 94XLT
  16. Spark Plug Gap
  17. Leaking Transmission and Exhaust Question
  18. I need a new Frame
  19. fuel pressure regulator?
  20. Coolant overflow problem!
  21. Was 4x4, shortbed, and dual fuel tanks ever an option?
  22. fuel leaking all of a sudden
  23. Headers for GT-40P heads?
  24. 93 Spindle Help
  25. My Trucks Smoking!
  26. Purge Solenoid
  27. 1984 F-150 4x4 300ci Inline 6 swap ?
  28. 1995 F-150
  29. Plug Wires
  30. warm up idle
  31. front bumper
  32. 302 Timing
  33. Eddie Bauer Colors
  34. leaking power steering fluid
  35. daystar installed
  36. 1994 5.0L 5-speed
  37. New FPR and it still won't start!!!
  38. wheres the grill screws
  39. Questions about Truck??
  40. 1994 mass air flow sensor
  41. 1989 F-150 Custom 4.9
  42. need computer code asap
  43. Steering noise
  44. need a computer codeasap
  45. does not go past 3500 RPM
  46. 86 F150 Box
  47. Where is the fuel pump relay?
  48. E250 5.0 Won't Start...help!
  49. 89 4.9V6 with black smoke won't start
  50. 1990 F-150 Engines Dies At Highway Speed Computer Codes Included.
  51. 88 F150/302 timing
  52. 86 F-250 window motor removal
  53. Idle problems
  54. Recently purchased 1995 4X4 F150 Super Cab 5.8L
  55. Anyone with a 460 please?
  56. Truck has the blues, smoke that is
  57. F150/250, same body?
  58. Just bought 95 f150 with jerking issues
  59. Truck ran rough then died
  60. truck cutting out
  61. My baby!
  62. Stalling while driving
  63. need help with vacuum line (see pic) thnx!
  64. just installed 3.73 gears limited slip
  65. High idle after TPS change????
  66. fuel pump
  67. K&N filter ?
  68. Shock preference?
  69. Who knows AOD's well?
  70. ailgate help
  71. heater motor resistor
  72. magnaflow muffler
  73. sluggish in first here and there
  74. 86 F150 lost all electrical - a bit stumped.
  75. Fan running...
  76. Where to get sun visors for '86 f150?
  77. A/C On = No Power...Help?
  78. spark plug wires
  79. Spark PLugs
  80. f150 fuel tank, what fits?
  81. New Member here with a 95XLT F150
  82. A/C vacuum question
  83. maximum tire size
  84. 4 wheel drive problems
  85. stock 302 engine for 1985
  86. truck problems.
  87. 4X4 Conversion
  88. Hi Everybody. (Noobie with a few questions.)
  89. Can't quite figure out what it is...
  90. First off, Hi everyone I'm Nick!
  91. Tune-up time! Need plugs, wires, etc... recommendations?
  92. auto hubs
  93. PKRWUD this one's for you
  94. Check Engine Light, Code PO 155
  95. Intro/4x4man Hub Noise(did Search)
  96. Right front hub
  97. What the hell is it?
  98. 94 f150 2wd 6 in lift on 34s
  99. Rear Springs
  100. back on the road
  101. 86 f150 302
  102. TPS is out of range
  103. How much collant in a 5.8?
  104. best engine/tranny to tow horse trailer?
  105. Does Anyone Know Torque/Procedure Rear Pinion Bearing 1996 F150
  106. AC compressor
  107. bad anitfreeze problem
  108. sounds like an orca
  109. seat for 89 f150
  110. 1995 F-150 5.8L... HP rating???
  111. EEC Ground Wire
  112. Finally got pics on here...
  113. Steering Gear Leak / Vacum Things
  114. Battery Keeps Dying
  115. Tires and front springs
  116. i have a really old tachometer and want to hook it up
  117. Upgraded Seats... Heated? Plus, How much should I Sell My Truck For?
  118. solid mounted fan to thermal clutched fan
  119. which fuel pumps are most common to fail in a dual tank truck?
  120. does my EGR vacuum regulator work??????
  121. Ammeter/alternator wiring...
  122. i cut my airbox
  123. intake mainfold and throttle body
  124. Can anyone run a Carfax?
  125. Cup holder inserts?
  126. spedo stoped working, shifts hard too
  127. '76 F150 stock grille w/ square lights
  128. same codes as before plus one new one
  129. New member with a project: 1995 2WD F150 with 4.6 SOHC and single turbo
  130. Where Can I Buy A 1979 F250-350?
  131. Transmission Question?
  132. Clifford=Christine
  133. Racing the engine
  134. Tips on removing O2 sensors
  135. Dana this, dana that....
  136. Wire bundle/plug in glovebox, 1985
  137. Will this cold air intake work on my 92?
  138. Just wanted to share...
  139. What years 300 I-6 are mass air?
  140. Tach and Transmission Temp Guages
  141. Inacurate gas guage, front tank only
  142. which f 150 is best for daily driver ?
  143. Fuel Press. Reg causing leak elsewhere?
  144. bigger throttle body
  145. what is this solenoid? what does it do?
  146. Coolant leak near TB?
  147. No Fire---help!!!
  148. Electrical Woes.. Air Bag Code 52
  149. Are any of your trucks this way?
  150. How do i know what transmission is in my truck?
  151. driveshaft?(1987 302 4 speed)
  152. over sized TB
  153. How do you put the rear seat down?
  154. Rough Idle
  155. 96 F150 Squeaking Rear
  156. What is the best oil and oil filter to use???
  157. oil filler cap?
  158. 94 Explorer Transmission Question?
  159. Headers on a 93
  160. what is it
  161. Power window wont go up 1990 f150 HELP!!
  162. 89 302 stalling problem,
  163. pcv and fuel filter issues
  164. 96 F150 Wiring
  165. Need a step by step of how to replace headlight lens?
  166. popping through carb
  167. new to Ford Trucks
  168. No cruise control
  169. Manual hub swap
  170. oil problems
  171. Questions with engine swap
  172. Mass Air Conversion - 94' w/EOD4
  173. MPG's
  174. Heated O2 Sensor
  175. 1990 4.9L Help
  176. Mass air injector harness
  177. check engine light
  178. it knocks when it sat all night
  179. 1995 Lightning
  180. Have question about F150 4.2 V6
  181. Did Ford make a diamond plate rear bumper factory?
  182. Super Swamper Tires
  183. Looking to buy an '89
  184. Which engine is more durable and reliable? 4.9, 5.0, 5.8?
  185. Fuel gauge acting up
  186. P0443 code. Help Please!
  187. 1994 302 V8 ?
  188. Two questions on Haynes procedures for 1991 5.0 F150
  189. 81 f-150 4x4
  190. check engine light
  191. Shift Cable ?
  192. Storage Options
  193. just bought a 94 f150 xlt 4x4
  194. headers
  195. Changing Injectors on a 4.9
  196. Time Get On With It Then
  197. pics of your truck
  198. fuel gauge
  199. 1989 Door Plate Codes
  200. 1995 stepside bed fender removal
  201. Horn does not work
  202. Which code scanner to buy?
  203. Intake manifold swap
  204. Foglights in grill
  205. So You Want REALLY bright headlights?
  206. Another stupid brakes thread
  207. Anyone got a sound clip of performance exhaust on a 4.9?
  208. Which front end?
  209. 79 F150 SuperCab flatbed needs...
  210. headlight dimmer switch
  211. EGR Check
  212. primary fuel pump
  213. 85 Blues
  214. Over Size Tires?
  215. How to change 94 F150 I6 oilpan???
  216. HELP ASAP with possible battery/cable problem?
  217. What is the HP and TQ rating on the 4.9?
  218. Tries to die/ Rpm surging
  219. Dashboard lights
  220. exhaust
  221. rear diff locking when 4wd is engaged
  222. Tips for replacing drivers side headlight?
  223. Newbie with a recently purchased 92 F-150
  224. Code 42
  225. Fuel tank interchange
  226. Temp Sensors & Factory Tow Package Wiring
  227. how much should i sell my truck for?
  228. center caps
  229. 1985 F-250 axle identification
  230. Alt wires go where?
  231. Sweet smell????
  232. Looking to get a F150
  233. Burning oil and antifreeze
  234. 92-96 front clip bolt on?
  235. Oxygen Sensor????
  236. Alternator probs...
  237. towing
  238. How to get drivers door to shut better.
  239. What kind of brake fluid for 92 f150
  240. Stripped Fill plugs
  241. brake lines are gay
  242. cold air intake help please
  243. Removing 94 door panel
  244. more DTC's! suuuuuuuuper!
  245. 15w-40, or 20w-50 w/ lucas?
  246. Problems starting
  247. Need your opinion guys...
  248. Bench with console?
  249. Oil pressure gauge on a 92 F150???
  250. 88 f150 wont fire
