won"t start
won"t start
1991 Ford F150 Long bed XLT 302 automatic. Driving down the road and dies. Turns over but will not restart. Towed it home. This is my fathers truck.
Do not hear fuel pump when turning the truck on. Only use rear tank. Front tank has not been used in years. Replace rear fuel pump. Still turns over but does not start. Do not hear fuel pump. Change Fuel pump relay. Still turns over but does not start.
Does not seem to get spark to the plugs. change coil, change distributor, change the brain on the side of the distributor and change the brain on the truck. Still turns over but does not start.
what next? Hopefully it's something simple that we have overlooked. Going crazy trying to get it running.
are u getting voltage at the conector?on the front side of the crossmember of the gas tank ware the wires comming from the sending unit come over and go into a conector see if u got voltage there. if not work your way back check the tank selector switch everything.
did u get a whole fuelpump/sending unit assembly or just the pump? if pump did u shrink wrap the wires
No power to the pump. But the guage has power. No power at the relay. I can not get any codes because it doesn't show any. I tried jumping the fuel pump at the code testing wires and still no pump.
The tank selector switch shows the back tank has gas when you put it on the back tank (put 7 or 8 gallons in after I put in the new fuel pump) and the front shows empty when it's on the front tank. Can the switch still be bad?
