AC question
AC question
1995 F150 5.0 V8, 150k. The clutch on the ac compressor is cycling like clockwork. It will engage for 2 seconds then disengage for 4 seconds, the engine will rev up a little during each cycle, the vents are blowing air, but not that cool crisp ac air, and smells slightly musty. Is the clutch going bad? I had the entire ac system replaced about 3 years ago. Luckily summer is over and not too hot down here. Thanks.
Either you have a leak, or it's so cool that the A/C isn't necessary, which will cause what you're describing. If it worked when the weather was hot, then don't worry about it. If this behavior started while it was hot, wait for a hot day and take it to a pro to find the leak.
Thats what I'm hoping. Refrigerant is pretty cheap and Autozone has the kit. Does anybody know what the pressure should be?? Thanks again, guys!!!
Thanks Steve83 and glc. Will have to wait till I get a few extra bucks to take it into an ac shop. Really sucks not having ac. System is only 3 years old!!!
