Finally Through State Inspect and Registered with Plates!!!
The truck has been in some state of repair for 7 1/2 months and never driven on the street. It was junkyard bound when I got it and could barely run for minutes when I got it. I put it on a trailer and brought it to the house. First sitting in the street, then the driveway and then finally in the garage. I have been into and repaired virtually every system on the truck, fuel, ignition, start circuit, egr, EEC circuits and switches, secondary air, lights, including instrument illumination, exterior and interior, signal lights, horn, wipers, speedo, brakes, cooling, blower, ac, heat, suspension, the 8.8 and the 44TTB, elec generation and distribution. I didn't have to get into internal transmission, engine internals and exhaust. I gutted and replaced the interior with the exception of replacing the dash pad. Wire brushed every bit of the frame with a high speed and painted with 3 coats of Rustuleum. I made some good mods, a locker in the back, a Rocksolid up front with a 10k winch, a tool box for the bed, warn premiums, transfer case skid plate, Bushwhacker flares. There are a few things left, 3g alternator, Hefty rear bumper with a spare tire carrier, rear tank skid plate, utility light for the bed and eng bay, body work and paint. Bed coating and a center console.
Well, here it is guys the nearly finished product. I want to thank all that have given guidance, in particular Steve83
Thanks.. just finished a major job. I pulled the transfer case,transmission, bellhousing. I replaced the rear main seal, resurfaced the disk, replaced the clutch, cleaned,resealed and painted the trans. Then I cleaned and resealed the t case. It was alot of work but needed to be done.
If the clutch master points up toward the front of the truck they get air locked and no amount of fluid will clear it.
Might have to take the master loose and point the front down hill to burp the air out. I know people who have gone through about 3 qts. of fluid trying to bleed out a clutch system. May not be your problem but it's worth a look.
