- Help !! my 4.6 has big problems
- FIPK..Many Posts About Noise & Squeals..Will I Have To DEal With This?
- How much for a serpentine belt???
- FIPK..Which One For 2003 Screw 5.4..Hard To Install?
- O2 Sensors Cheap !!
- engine swap
- I'm driving a rental....
- oh..oh..ohhh mmmannn!!!!!..
- Performance numbers
- Po' Boy Induction
- 5.4 in the 2000 F-150's, any flaws?
- Should I buy 98' f150 4x4?
- Antifreeze change?
- New 4.6/5.4 Windsor Aluminum Valve Covers almost ready!
- Air Force One and Noise
- How do I "properly relieve fuel line pressure"?
- 5.4 oil leak
- 1996 check engine light
- Technical Info on changing plugs
- Mechanic n00b with a few basic questions.
- Rough Idle When Parked
- Stock Horsepower for 4.6?
- help
- electric fans
- AC Compressor runs with Vent on Floor/Panel
- High Mileage 4.6L
- SOunds Like a Diesel
- How can i turn off the check engine light?
- Ever Heard Of Microlon..Metal Treatment For Your Engine?
- Changing sparkplugs
- Help with a couple of questions
- Top dead center- Mark on Driver's head?
- 95 throttle body
- Optima or Exide Orbital
- The Caddilac Sixteen
- JET Low Temp. thermometer 180 degrees...
- Long Term Solution for Pinging
- FIPK problems
- airbag light flashing code???
- 97 4.6L V8...Any problems to look out for? Piston Slap? what is it?
- refused delivery on 03, has old head design
- Shell, Chevron, Texaco merger...
- Compressor Noise
- What heads will work?
- How can you tell if the fan clutch needs replacement?
- 04 5.4 GPM - anyone know?
- Engine Oil/Types ?
- Piston slap on 2001-5.4
- Oil leak (will it happen again)
- 97-99 4.2's MUST READ!
- Check engine light
- Worked on timing cover, now it won't start
- 97 4.6 running terrible
- Oil Pressure Light
- DPFE and EGR....did I just get skrewed???
- Keeping water out
- Which sparkplugs
- Oil Leak
- my engine is driving me nutz
- Airforce One Installation Question
- How do you disconnect wires to MAS
- Oil Pressure
- spitting out coolant all the time
- changing to larger radiator?
- Need advice after heads are replaced.
- Flat spot ?
- Power Pulley's
- 5.4 & 4.6 Embelms Get'em here cheap
- Superchip - Need Help
- Lunging at startup?
- Hypertech programmer?@
- What are you paying for gas?
- SOHC to DOHC
- TB installation
- Fuel Starvation
- leak in timing chain cover
- 2002 f150 shortbed 4 x 4 fuel economy
- 4.6 Head Gasket Leak
- Whining noise
- 4.6Intake Manifold Questions
- Major oil usage/ Valve guide seals?
- Oil Usage
- no start??
- '97 4.6l v8 missing intermittently still
- Mystery Leak?
- Just started with bad miss and hesitation
- closed hood dyno
- I am runnig out of ideas!
- 4K mi. left on factory warranty, what to look for?
- Bad gas milage, whats causing it??
- 2 Probs with 4.6 and tranny
- Newbie needs help!
- 4.6 Valve Ticking Noise
- Fuel Pump Conspiracy 1990+
- Blew 30 amp fuse?
- Replacing serpentine belt
- my 98 just failed emissions/ check engine
- Engine starts then dies when it is REAL cold
- Ford Coolant Loss (from ASE Tech Tips)
- Whats Happening to my MPG?
- What kind of coolant with the 5.4l?
- 4WD 1/4 mile times
- K&N filter
- How to know of a O2 sensor problem?
- What should my MPG be?
- Cleaning MAF Sensor
- 5.4 Gas mileage question
- need help with fuel filter issues.....
- Help! cold starting problem!
- which gear
- Cruise control is dead......
- If timing chain is not on right, how will my truck run?
- Check engine light after oil change
- Water Wetter?
- dyno
- TB's Are they effective?
- Piston swap in a 300
- Plug gap for 4.2?
- Plug Wire Q
- '97 4.2 Fun - 4th new engine
- p0171 and 0174 need help asap
- Warranty gremlins
- Best mod for a 1999 F150 Supercab?
- Amsoil users
- 5.4 with current gas prices
- Instrument Cluster Test Mode...
- mileage vs. performance
- Lock Tite on Sparkplug threads?
- Error Codes P0172 and P0175
- Pulling out 97' 5.4 NEED HELP
- 99 150 both heads leaking. (what to expect from FORD)
- Bad Running F150 5.0
- starter
- Steeda or ASP?
- Well It's Finally Mine!!!!!!!!
- Engine Rebuild Cost Est.
- Running Air Conditioning - effect on MPG
- air inlet
- Replacement filter for Airforce one
- Poor man's intake
- need an engine
- 6.0 PSD Problems.. Already
- vacume presure to the egr?
- Tailgate's effect on MPG
- 4.2 Engine hiss after shut down
- Tachometer placement and installation.
- bad miss
- Just bought Castrol Synthetic blend 5w20 today.
- Has any used Fram X2 oil filter
- PI (Power Improved) heads
- thank you
- Clattering noise when starting out...
- I Need Power!!!!
- Variations of 4.6
- Question about OBD II Scanners
- 1998 F-150 Odbii P0401
- Code 102 - EGR valve replacement
- Is there a way to find out actual mileage?
- computer Update or reburn
- quick change oil plug
- Hankering for an F150, couple ?'s
- no oil pressure when cold
- Rough Idle
- Changing oil w/fFabtech 6" liftkit
- Mineral spirits as injector cleaner?
- Heater core problem with 150's???
- HD engion vs Lightning
- People with 3.73s and 4.10s
- ford vs. the rest
- 4.6L 0-60 mph
- Kool Blue Air Filter
- O2 Sensor
- Coolant leak question
- 5.4L misfire??
- Engine Shudder
- '97 4.6 crap'n under load
- TB Question
- 300I6 and 4.6V8
- wont crank. wont even start
- Time to set everything straight.
- 4.6 to 5.4 swap
- ignition starter lever '90 150 tilt wheel
- 5.4L gas mileage tricks?!
- I found Neal's Chevy twin LOL
- 4.6L gas mileage????
- New Polysynthetic oil - good for 30,000 miles
- 60,000 mile tune up
- Oil filter relocation
- 97 5.4 engine noise.
- Navi to F-150
- Engine bucks severely under any load 1990 5.0
- Service engine soon light stays on
- 302 Ho
- synthetic oil
- Mods, pinging, and maintenance
- 93 F150 5.0L Finally died. Suggs?
- Lightning motor in 98 Navigator
- '01 F150 S'crew NOT getting hot
- K&N FIPK installation observations
- It's gotta be the gas!!!
- Oil Sensor (How do you take it off)
- intermittent idle
- Possible fix for cold startup squeal
- Dealers, what a joke.
- Changing out TB
- I think I found a problem with an ignition wire!
- ??IAC valve install question??
- Engine Error Code Help
- All Ford Owners Read
- 460 engine swap?
- 460 engine swap?
- Engine conversions
- Well, here we go again!
- Water Pump Help
- Cruise Control/Remote Starter
- gas filter clips
- Does anyone buy synthetic blends?
- Back to the $#%^%$#@ shop!!!!
- Oil Recommendation for High milage 5.0L
- Oil Misconceptions...
- Best way to check for a vacumn leak
- has anyone gone from 5-30 to 5-20...
- 5.4 Horsepower
- is 10W-40 overkill?
- Where does this wire hook up????
- Check engine LIGHT AGAIN!!
- Misfire ad nauseum
- Steam from tail pipes after engine is cut off....is this normal?
- What should it idle at?
- New Filter
- Final request for help then I'm off to the dealer
- Reman "engine" is done & home.
- Electrical Temp gauge reading off by 15*????
- ?'s for those with Plasma Boosters
- Typical performance upgrade questions
- Airaid users?
- which spark plug is best?????
- Idler Pulley
- Needs for supercharger?
- A motor is a motor is.........?
- What Changes Can I do under Warrenty
- Need Help
- Bad miss when warm??
- Egr
- rear plug removal on 98 F150 4.6
- OK guys, come clean...who`s using 5W30 oil instead of the recommended 5W20?
- Missfire in #4 (AGAIN!!)
- OK....this is REALLY gettin' old....pls help
- K and N filter
