blown plug helping out.
Old Jul 5, 2006 | 10:10 PM
racerf150-2's Avatar
hey everyone i kno every single person has heard about this problem, my dad just went through it with my truck. he was towing the pontoon boat to the cabin and when he went to accel on to the interstate bam it happened, took out my plug, head, cop, volant intake tube. I plan on timesertting it soon. It may not be a big deal but i think everyone should go http://www-odi.nhtsa.dot.gov/ivoq/ and will out a complaint, i know many of you have already. It takes about 5 min to do and is simple. thanks for your time guys
Old Jul 6, 2006 | 12:23 PM
Triton_Tophe's Avatar
I recommend the timesert kit....I just did my repair yesterday and so far it seems to be working great. The kit they have designed is specific to our trucks and works great. Took me about 5 hours to complete the whole job. Could probably do it in 4 if I had to again. I also filled out a complaint at consumeraffairs.com.
Too bad you dont live in MI, you could use my tools! Good luck, and take your time on the repair. Check all your other plugs while youre in there.
Old Jul 11, 2006 | 10:56 AM
tomlin's Avatar
Thumbs down
Looks like the NHTSA has bailed on this issue. Read this.
NHTSA Action Number: NHTSA Recall Campaign Number:
DP05005 N/A
Make: FORD Model: F SERIES (LIGHT)
Manufacturer : ACCUBUILT, INC.
Year : 2000
Component :
ENGINE AND ENGINE COOLING
ENGINE AND ENGINE COOLING:ENGINE
ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Date Investigation Opened : September 22, 2005
Date Investigation Closed : January 4, 2006
Summary:
ON SEPTEMBER 6, 2005, ODI RECEIVED A PETITION REQUESTING THAT THE AGENCY INVESTIGATE ALLEGATIONS OF ENGINE SPARK PLUG EJECTION IN CERTAIN MODEL YEAR 1997 THROUGH 2004 FORD VEHICLES WITH TRITON V-8 AND V-10 ENGINES. ODI RECEIVED A TOTAL OF 474 NON-DUPLICATIVE COMPLAINTS ON THE SUBJECT VEHICLES WHERE THE COMPLAINANT, OR THE DEALER REPAIRING THE VEHICLE, REPORTED THAT A SPARK PLUG DETACHED FROM THE CYLINDER AND/OR EJECTED FROM THE ENGINE. AS OF DECEMBER 8, 2005, ODI IS NOT AWARE OF ANY ALLEGATIONS WHERE THE ALLEGED DEFECT RESULTED IN A LOSS OF VEHICLE CONTROL, A CRASH, AN INJURY, OR A FATALITY IN ANY OF THE 10,319,810 SUBJECT VEHICLES. IN ADDITION, ODI IS AWARE OF ONLY TWO INCIDENTS WHERE THE VEHICLE STALLED WITHOUT RESTART. INFORMATION CONTAINED IN THE ODI CONSUMER COMPLAINTS AND OBTAINED FROM 72 TELEPHONE INTERVIEWS WITH COMPLAINANTS SHOWED THE FOLLOWING: (1) 99% OF THE COMPLAINTS WERE ON MY 1997 TO 2002 SUBJECT VEHICLES. (2) MOST THE COMPLAINANTS REPORTED HEARING A LOUD POP WHILE DRIVING OR UPON STARTING UP THE VEHICLE FOLLOWED BY A LOUD, REPETITIVE CLICKING OR POPPING SOUND. (3) MANY OF THE COMPLAINANTS REPORTED THAT THE POPPING SOUND WAS ACCOMPANIED BY SOME LOSS OF VEHICLE POWER; HOWEVER, IN 99% OF THE INCIDENTS REPORTED, THE VEHICLE DID NOT STALL. IN THE VERY FEW INCIDENTS WHERE THE VEHICLE DID STALL, MOST VEHICLES COULD BE RESTARTED. (4) ONLY A SMALL PERCENTAGE OF THE COMPLAINANTS CITED THAT THEY SMELLED GAS OR A SLIGHT BURNING SMELL WHEN THE INCIDENT OCCURRED. (5) IN ALL BUT A VERY FEW INCIDENTS, VEHICLE DAMAGE WAS LIMITED TO THE ENGINE. IN ONE INCIDENT, THE COMPLAINT REPORTED THAT THE FUEL RAIL WAS DAMAGED AND REPLACED AFTER ONE OF THE SPARK PLUGS EJECTED FROM THE ENGINE; HOWEVER, THE COMPLAINANT REPORTED THAT THE DAMAGE DID NOT RESULT IN ANY TYPE OF FUEL LEAK OR FIRE. IN ANOTHER INCIDENT, THE ONLY INCIDENT WHERE A FIRE WAS ALLEGED, THE COMPLAINANT REPORTED THAT NO FLUID LEAK WAS OBSERVED, BUT THAT A FIRE RESULTED AFTER THE SPARK PLUG HAD EJECTED FROM THE ENGINE AND HE HAD RESTARTED THE VEHICLE AND DRIVEN TO ANOTHER LOCATION. NONE OF THE COMPLAINANTS REPORTED ANY DAMAGE TO THE VEHICLE HOOD. (6) ONLY TWO COMPLAINANTS REPORTED THAT THEY OBSERVED WHAT APPEARED TO BE SOME DROPS OF FUEL COMING FROM THE CYLINDER WHERE THE SPARK PLUG HAD FAILED OR ON THE SPARK PLUG ITSELF; HOWEVER, EACH OF THESE COMPLAINANTS REPORTED THAT THERE WAS NO SMOKE OR FLAMES AS A RESULT OF HIS INCIDENT. AS THE PETITIONER NOTED, AND ODI’S ANALYSIS SHOWED, IT IS POSSIBLE FOR A SPARK PLUG TO DETACH FROM THE ENGINE CYLINDER THREADS IN THE SUBJECT VEHICLES. HOWEVER, ODI’S ANALYSIS OF 474 COMPLAINTS DESCRIBING SUCH INCIDENTS FOUND ONLY A VERY FEW ALLEGED ANY SAFETY-RELATED CONSEQUENCES. NONE OF THESE SHOWED ANY EVIDENCE OF A SERIOUS SAFETY CONSEQUENCE. GIVEN THE LARGE POPULATION AND RELATIVELY LONG EXPOSURE TIME OF THE SUBJECT VEHICLES, THE COMPLAINT ANALYSIS INDICATES THAT THE RISK TO MOTOR VEHICLE SAFETY FROM THE ALLEGED DEFECT IS VERY LOW. IN VIEW OF THE FOREGOING, IT IS UNLIKELY THAT NHTSA WOULD ISSUE AN ORDER FOR THE NOTIFICATION AND REMEDY OF THE ALLEGED DEFECT AT THE CONCLUSION OF THE INVESTIGATION REQUESTED IN THE PETITION. THEREFORE, IN VIEW OF THE NEED TO ALLOCATE AND PRIORITIZE NHTSA’S LIMITED RESOURCES TO BEST ACCOMPLISH THE AGENCY’S SAFETY MISSION, THE PETITION IS DENIED
