wondering????
Old Jul 11, 2006 | 07:20 AM
hulkster55's Avatar
wondering????
is the 4.6 engine really sub par to the 5.4
Old Jul 11, 2006 | 09:04 AM
kr1mson k1ng's Avatar
Yes, that's why they call it a 4.6 rather than a 5.4
Old Jul 11, 2006 | 09:10 AM
Johngs's Avatar
Depends on who you ask...some people are convinced the 4.6L is a better engine.
But nearly every person I have heard of that has gone from the 4.6 to the 5.4 said it was worth the change.
Oh and I am not saying the 4.6 is a bad engine...its a very good all around engine, but if youre looking for power, get the 5.4
Old Jul 11, 2006 | 09:19 AM
JMC's Avatar
JMC
25 Year Member
The 4.6 will get the job done. The 5.4 will make it easy. The 5.4 has more torque. I did an engine swap from a 4.6 to a 5.4. The difference was amazing.
JMC
Old Jul 11, 2006 | 10:59 AM
hulkster55's Avatar
thanks jerkoff!!!
Old Jul 11, 2006 | 11:26 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Ford makes a profit on everything.
If extended warranties cost $2000 then Ford is making $1,000 on each.
If the 5.4 costs $1,500 more, then Ford thinks the 4.6L is sub-par by $750.
Some owners needed it.
Some owners just wanted it.
Some owners figured they could live without it.
Old Jul 11, 2006 | 11:34 AM
JMC's Avatar
JMC
25 Year Member
Just some numbers gleaned off Ford from different sources.
The torque converter for the 4.6 has a multiplication ratio of 2.3:1 and a stall speed 2105-2505.
The 5.4 has a multiplication ratio of 1.9:1 and a stall speed 1830-2190. They both use the same automatic tranny so that just shows you how much more power the 5.4 makes and at a lower rpm.
JMC
Old Jul 11, 2006 | 12:27 PM
chester8420's Avatar
I like this description. It's like comparing a psd f-350 to a 5.4 f-350. Is there anything that the psd can do that the 5.4 can't? Aside from pull the same loads a little faster, and accelerate a little better, NOPE.
If you have the 4.6, REJOICE in the good gas mileage!
