Water temp sensor
Old Jun 28, 2006 | 08:24 PM
SKRWZ's Avatar
Water temp sensor
I want to put in a aftermarket water temp gage but where is a good spot on putting the temp sensor ? its on a 98 5.4 motor any suggestions ?
Old Jun 28, 2006 | 09:19 PM
JMC's Avatar
JMC
25 Year Member
Driver side block drain plug.
JMC
ROTATE CLOCKWISE 90°
Old Jun 29, 2006 | 10:41 AM
MitchF150's Avatar
I put mine on the inlet side of the heater core hose. I used a brass tee and additional hose attaching hardware from Home Depot. I think it was the 5/8" size?? Since I used electric gauges, I needed to run an extra ground wire from the tee to the chassis.
Works great and has been setup this way for about 4 years now. I also have a trans temp gauge setup in a similar manner on the output line, just before it goes into the rad... Tells me everything I need to know how hard the engine is working.... Especially when towing my trailer.
Mitch
