99 f150 cam sensor signal/fuel system
Old Jul 6, 2006 | 05:36 PM
lando10101's Avatar
hi all, my 99 f150 4.2 died had to jump the fuel relay to start..showed various codes including 0340 cam position sensor so i replaced it and still nothing...if i do not jump terms..at the fp relay i have no fuel and also the mileage(digital)odometer will not mark just shows ------. when i jump the relay to get the fuel system to work the odometer works and the truck starts...the only other codes are 1520 i.m.runner control circuit fault (?????) and 0443 evap purge control valve circuit malf.. and various tranny codes..please help thanks
Old Jul 6, 2006 | 05:46 PM
JMC's Avatar
JMC
25 Year Member
What terminals do you jump?
JMC
Old Jul 6, 2006 | 05:59 PM
lando10101's Avatar
terminals
i jumped the main relay terms..30 and 87 and 86..was more of a hit and miss thing...
Old Jul 6, 2006 | 08:01 PM
Quintin's Avatar
Was the cam sensor broken when you replaced it? Normally what happens is the sensor breaks (usually from the sychronizer binding up) and gets mangled by the reluctor wheel inside the synchronizer. If you left a piece of the magnet from the old sensor in the synchronizer, you'll still get a no-start.
Old Jul 6, 2006 | 08:26 PM
lando10101's Avatar
i did not notice any debris..but i will recheck i still have the old one i will get back as soon as i check...thanks
Old Jul 6, 2006 | 08:40 PM
lando10101's Avatar
nope i looked at the old one and it is intact..
Old Jul 7, 2006 | 02:00 PM
JMC's Avatar
JMC
25 Year Member
Check fuse #23 in the Battery Junction Box.
JMC
Old Jul 8, 2006 | 08:27 AM
lando10101's Avatar
will double check ..just wondering does the defective cam sensor (if it is that)cause the fuel pump relay to trip and also keep the odometer from reading properly>????does the intake runner control valve code tie in to all of it i have never pulled that code//??thanks for the help all...this old lone star edition 99 looks to good to be parked...
Old Jul 8, 2006 | 10:30 AM
JMC's Avatar
JMC
25 Year Member
Fuse #23 sends 12v to power amoung other things the Cam sensor and the IMRC.
JMC
PS. Can you list all the codes?
Old Jul 11, 2006 | 10:41 PM
lando10101's Avatar
hey jmc thanks for the continued effort..just getting back in town..i will go through my charts and let you know what codes came out..
Old Jul 11, 2006 | 11:38 PM
lando10101's Avatar
ok here come the codes i pulled...0340-cam sensor+1520 imrc+1747-elec press cont solenoid short+0443-evap emm. cont sys purge control valve+1409-egr evr control circuit fault+0750-shift sol a+0755-shift sol b+0743 torq con clutch elec.+1451 man specific powertrain+(these next ones are o2 sensor related and are prob. due to the fact that the "cats are running empty" been like that for awhile)and they are 0135+0141+0155+0161
Old Jul 12, 2006 | 04:35 PM
JMC's Avatar
JMC
25 Year Member
Codes 1520 1747 0443 1409 1451 0135 0141 0155 0161 all have Open VPWR circuit as a possible casue. Check fuse #23 in the battery junction Box.
JMC
Old Jul 22, 2006 | 11:29 AM
lando10101's Avatar
thnks for the info. i will update as soon as poss..i have been very busy lately i have the county road dept. account and they decided to repair several of their big rig a/c systems..business has been good this mth. i do appreciate your help..by vpwr circuit you do mean power to the #23 fuse??
Old Jul 22, 2006 | 11:38 AM
JMC's Avatar
JMC
25 Year Member
That fused circuit is the vehicle power circuit. If that fuse is burnt then the circuit will be open.
